j.m.
NC, USA Status: offline
sorry man, not trying to bash on you, but what part of direct drive didn't you understand? A very large outrunner is mounted right where the center diff is. B-boy, you might want to consider supporting the other side of the motor as well. You can do it by simply having a bearing around the shaft, and the bearing mounted into a block of *something* mounted where the other bulkhead goes.
_____________________________
!Signature your in it put, this read to time the took you If If the World didn''t suck, then we would just fall off.
