RE: Electric RAZE!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Electric RAZE!
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Electric RAZE! - 8/13/2007 12:20:20 AM
brushlessboy16
Status: offline
ok thats good to know b4 hand. thanks
what are your feelings on plastic motor mounts studysesion?
< Message edited by brushlessboy16 -- 8/13/2007 12:21:17 AM >
_____________________________
Brushless Cen Matrix TR
v3 Mamba monster
(in reply to studysession)
       Post #: 76
RE: Electric RAZE! - 8/13/2007 12:23:38 AM
brushlessboy16
Status: offline
studysession do u have links to any other 1/8 scale b-less conversions?
v3 Mamba monster
(in reply to brushlessboy16)
       Post #: 77
RE: Electric RAZE! - 8/13/2007 12:36:06 AM
studysession
Status: offline
Not exactly but this is good enough to get you started. Just search ggogle -
http://www.google.com/search?hl=en&q=brushless+conversion+1%2F8+scale+buggy
Plastic motor mounts? Can't imagine them being very sturdy vice aluminum or mild steel.
http://studysession.com
http://www.rcuniverse.com/forum/m_6346863/anchors_6346863/mpage_1/key_/anchor/tm.htm#6346863
       Post #: 78
RE: Electric RAZE! - 8/13/2007 12:43:16 AM
brushlessboy16
Status: offline
yes but i do not have a brake press to bend steel. can weld two peices together... thanks for the link SS
v3 Mamba monster
       Post #: 79
RE: Electric RAZE! - 8/13/2007 12:46:18 AM
Takedown
Status: offline
quote:
ORIGINAL: brushlessboy16
You should search around for 90' peices of steel that you can carve into a motor mount. Im sure it will be pretty cheap to make.
Lamborghini''s = True Engineering Marvels
       Post #: 80
RE: Electric RAZE! - 8/13/2007 12:50:55 AM
brushlessboy16
Status: offline
i have some thick aluminum sheets, idk if the are any good, i can make it outta steel though, does anyone know what thread nitro motormount screws are?
v3 Mamba monster
(in reply to Takedown)
       Post #: 81
RE: Electric RAZE! - 8/13/2007 12:52:49 AM
studysession
Status: offline
Here's mine:
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=467
As you can see in the link above, I mounted mine to the same screw holes where the diff is located. Making it where I did not need to worry about the 90 degree bend you are asking about. Get creative and see what you can do.
< Message edited by studysession -- 8/13/2007 12:54:34 AM >
       Post #: 82
RE: Electric RAZE! - 8/13/2007 12:55:38 AM
Takedown
Status: offline
Pretty cool. How fast you think its going?
       Post #: 83
RE: Electric RAZE! - 8/13/2007 12:57:04 AM
studysession
Status: offline
Depends on the motor mount and brand and make etc... Not standard. A lot of time for 1/8 scale they will either be 4mm machined fine thread or 3mm machined fine thread. Not for all though. They have tools that you use to determine the thread and pitch if you don't already know.
       Post #: 84
RE: Electric RAZE! - 8/13/2007 12:58:13 AM
studysession
Status: offline
quote:
ORIGINAL: Takedown
Easily over 40 or so when I did the article. With more cells would of been faster. Now need a new motor. After a few years of use the end bell came off the Fiegao 10L and do not know what I did with it.
       Post #: 85
RE: Electric RAZE! - 8/13/2007 1:04:05 AM
brushlessboy16
Status: offline
nice. but i have no means of machining something like that... im workin with what i have
v3 Mamba monster
       Post #: 86
RE: Electric RAZE! - 8/13/2007 1:07:08 AM
studysession
Status: offline
True - just showing if you measure the holes for your diff's. You could drill and make something similar.
       Post #: 87
RE: Electric RAZE! - 8/13/2007 1:09:20 AM
Takedown
Status: offline
Or studysession could possibly make a mount for you if you have the exact measurements on everything and sell it to you.
       Post #: 88
RE: Electric RAZE! - 8/13/2007 1:11:40 AM
brushlessboy16
Status: offline
too bad im broke..hahaha, i did measure the diff holes for the first prototype, but i might use the 2nd gen, idk yet.
v3 Mamba monster
       Post #: 89
RE: Electric RAZE! - 8/13/2007 1:11:42 AM
studysession
Status: offline
quote:
ORIGINAL: Takedown
That would be true in a few months but not right now. In a few months when my new CNC router is finished, if you draw it in a CAD program I would be able to cut it for you. But not right now.
