eflowmit
Joined: 6/16/2007 From: Hagerstown, MD, USA Status: offline
Well, after about 20 flights my belt was clicking lightly again - adjusting the tension did not get rid of it. After another four flights, with the tension slightly looser than the manual says (but not by much), something seemed to be binding, so I shut down and the blades were hard to turn. It seems the belt jumped on the tail shaft. I saw a couple of tiny, short threads in just one area, so I singed them with a match (very carful not to melt the rest) The teeth seem fine, so I am keeping it on and going back to the manual recommended setting. I will continue to carefully inspect the belt between flights. If I do have any problems, the ground is usually only a few feet away as I am still practicing my nose in hovering. Has anybody else tried the WD-40 trick? Thanks again, Tim
