RE: Phase 3 EF - 16
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: Phase 3 EF - 16 Page: <<   < prev  4 5 6 7 8 [9] 10 11 12 13   next >   >>
Login
RE: Phase 3 EF - 16 - 3/24/2009 6:41 PM
glm
Score: 100
Last Login: 3/10/2010
Status: offline
Hi All,
I’d like to introduce an ESC Fairing for the Phase 3 EF-16.
http://morganmill.com/RC/rc-site-10-7-08_029.htm
What could be done in hours is now possible in minutes. The ESC Fairing is a drop in aerodynamic enhancement for the interior of the duct in front of the fan. The ESC Fairing covers the wires and sharp edges in the motor compartment while creating laminar flow where it’s needed the most in a ducted fan – right in front of the motor. This should gain you performance and speed across the wide range of motor and fan configurations possible with this aircraft.
Weather it’s a stock motor on 3 cells or one of the high performance setups on 4 cells covered in detail in this thread - it will add speed and performance to an already outstanding performer at next to nothing in weight and installation time.
The mold was machined such that it provides suggested cut lines for an optional oval shaped hole at the rear of the battery compartment and necessary cooling hole cut lines for the stock ESC location.
Hot air from the battery compartment is exhausted through the rear hole and out around the ESC Fairing through the cheater holes. If you choose to close your cheater holes you can use the optional oval hole to exhaust hot air into the fan itself. See installation suggestions on the web site.
The ESC Fairing will fit the stock fan shroud and any 70mm setup and is placed between the belly pan and the main fuselage. Used in conjunction with The Cheater Hole Supports it makes for a superb installation setup.
Made from High Impact Polystyrene.
Thanks for looking!
Gary
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to phippsa3)
       Post #: 201
RE: Phase 3 EF - 16 - 3/24/2009 6:52 PM
crashcrash
Score: 144
Last Login: 3/16/2010
Status: offline
quote:
ORIGINAL: glm
Hi All,
Thanks for looking!
Gary
Gary...NOW there's a useful unit. It keeps the wires at bay and cleans the area up in front of the fan. I'm fairly impressed with this because I used clear packing tape to hold servo extension wires down and the ESC wires....this does it all, and cleanly I might add. Since it does hold the ESC down in it's proper spot, that should make things a lot easier too. GOOD JOB on this one.
_____________________________
Now you did it!!!
Hide Signatures
(in reply to glm)
       Post #: 202
RE: Phase 3 EF - 16 - 3/24/2009 7:40 PM
glm
Score: 100
Status: offline
Thanks Crash,
Cheers!
Gary
Hide Signatures
(in reply to crashcrash)
       Post #: 203
RE: Phase 3 EF - 16 - 3/24/2009 8:34 PM
crashcrash
Score: 144
Status: offline
I made my air intake removable on my current F-16, which already saved the day when I had a servo fail. I get paid tomorrow, I'll check the finances, I may buy this unit....it's a great upgrade, and I can get rid of the packing tape in the air chamber.
Now you did it!!!
Hide Signatures
(in reply to glm)
       Post #: 204
RE: Phase 3 EF - 16 - 3/25/2009 9:01 PM
phippsa3
Score: 100
Last Login: 3/12/2010
Status: offline
Started putting together my new f-16 today.
Using a HET 6904 fan and HET 2w 23 motor.
60 amp esc. Had to melt away a little foam to get the bits and pieces in.
Using a 4cell 25c pack. Hitec hs65 servos and Futaba 2.4 reciever.
Should be super quick and unlimited vertical
Click for fullsize
Saito club member #586
Hide Signatures
       Post #: 205
RE: Phase 3 EF - 16 - 3/25/2009 9:59 PM
crashcrash
Score: 144
Status: offline
quote:
ORIGINAL: phippsa3
It's gonna be INSANE......LMAO.....
Now you did it!!!
Hide Signatures
       Post #: 206
RE: Phase 3 EF - 16 - 4/13/2009 10:22 PM
skyracer068
Score: 100
Last Login: 3/3/2010
Status: offline
quote:
ORIGINAL: phippsa3
The 2W-23 works best on a 5s 2500 25c pack producing 950 watts and drawing 50 to 52 amps. The 2W-20 is designed for 4s use. I'm running both motors in my 16s and both have unlimited vertical.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 207
RE: Phase 3 EF - 16 - 4/14/2009 12:35 AM
phippsa3
Score: 100
Status: offline
4 cells is a squeeze.
Dont think i can get 5 cells in there lol.
Hide Signatures
(in reply to skyracer068)
       Post #: 208
RE: Phase 3 EF - 16 - 4/14/2009 3:57 AM
crashcrash
Score: 144
Status: offline
quote:
ORIGINAL: skyracer068
quote:
ORIGINAL: phippsa3
Nice ships dude...... Here's a pic of mine, which has landing gears and steerable nose wheel BTW.
Click for fullsize
Now you did it!!!
Hide Signatures
       Post #: 209
RE: Phase 3 EF - 16 - 4/14/2009 4:00 PM
skyracer068
Score: 100
Status: offline
quote:
ORIGINAL: phippsa3
During our last electric fun fly, one gentleman from Arizona had a 5s 3300mAh pack stuffed in his EF-16. That battery and the ARC motor he was running, he knocked off a speed run of 177 mph. A little carving and glassing is required to get a 5s in but worth it!!
Hide Signatures
       Post #: 210
RE: Phase 3 EF - 16 - 4/14/2009 4:12 PM
phippsa3
Score: 100
Status: offline
Im tempted now.
What size speed controller was he using?
Hide Signatures
       Post #: 211
RE: Phase 3 EF - 16 - 4/14/2009 8:15 PM
-pkh-
Score: 102
Last Login: 3/15/2010
Status: offline
I just got one of these, haven't put it together yet.
What's the consensus on keeping the tailerons from getting ripped off on landing? Is it easy enough to flare and then release before touchdown to keep the leading edge from catching, or is it wise to rig up (or buy) some ventral fins to prevent this? The stuff on the Morganmill website looks cool, but it's hard for me to justify spending $18 on a set of fins for a $99 plane.
Thanks!
Paul - Helis: Two Raptor 50V2s, Venture 30CP, Blade CX2
Planes: Twist 60, Tribute 36, Two PZ BL P51s, Two F27C Strykers
Hide Signatures
       Post #: 212
RE: Phase 3 EF - 16 - 4/14/2009 9:34 PM
skyracer068
Score: 100
Status: offline
quote:
ORIGINAL: phippsa3
Im tempted now.
He is running a Castle 125 with the ARC motor. In both of mine in which I'm running a the HET 2W-20 (and a 4s 2500 mAh) an 2W-23 (and a 5s 2500 mAh), I have 80 amp ESC installed.
With the HET 2W-23 and 5s 2500 mAh, you can expect to see speeds of 145-155 mph with a flight time of 5 to 6 minutes with throttle management.
< Message edited by skyracer068 -- 4/14/2009 9:37 PM >
Hide Signatures
       Post #: 213
RE: Phase 3 EF - 16 - 4/14/2009 10:06 PM
crashcrash
Score: 144
Status: offline
quote:
ORIGINAL: -pkh-
Thanks!
Of course you do the upper and lower lamination with .030 plastic to re-enforce that weak area where the tailerons go through the foam. I have ONCE knocked my taileron hard enough to warrant re-enforcement of the inside and outside panels...then repair. The field I fly in is a little less than groomed to lawn status...things catch. If it were lawn type groomed....you should be able to grease it in with NO damage. Other than that...I have a LOT of landings that incur no damage.
Now you did it!!!
Hide Signatures
(in reply to -pkh-)
       Post #: 214
RE: Phase 3 EF - 16 - 4/14/2009 10:29 PM
sanman55
Score: 100
Last Login: 3/14/2010
Status: offline
Hey PKH.......I did not like the fins.. They grab too much and u end up slaming the nose down.
I do what you suggested, just before touch down I release the elevator.. This works nice..
Have fun
< Message edited by sanman55 -- 4/14/2009 10:30 PM >
Hide Signatures
       Post #: 215
RE: Phase 3 EF - 16 - 4/14/2009 11:40 PM
glm
Score: 100
Status: offline
quote:
ORIGINAL: -pkh-
Thanks!
Look at the Belly Pan Kit - there is a Intake skid / Antenna in the kit. Saves the the Belly pan from fast landings and ingesting a few less rocks and other goodies and wrecking the fan. You get a kit price that saves you $6.00 off seperate parts.
Hobby People doesn't sell just the Belly Pan either - the parts only kit is $64 most of the time and $49 when you can catch it on sale. One rough landing and it's $49 - $64 bucks. You make the choice.
With the Fins installed you can flare the landing a lot more than with out - as you can use the tailirons all the way to touch down.
But hey that's just me and I am bias
Hope this helps and whatever way you go - have fun!
Gary
< Message edited by glm -- 4/14/2009 11:43 PM >
Hide Signatures
(in reply to -pkh-)
       Post #: 216
RE: Phase 3 EF - 16 - 4/30/2009 7:29 PM
06sportster
Score: 100
Status: offline
I have always wanted an EDF plane. I think I may have finally decided on the Phase 3 F-16. I do have a question about the 3 different forms you can buy it in from Hobby People. Is the kit with the motor/fan/esc worth getting (this one). Or would I be better off to get the kit with out it and add my own esc/motor/fan setup (like this one)? What's a good recommended power set up for this one?
Last question is, what's the difference in the 2 kits, besides $20? (cheaper kit)
Hide Signatures
(in reply to glm)
       Post #: 217
RE: Phase 3 EF - 16 - 4/30/2009 7:37 PM
crashcrash
Score: 144
Status: offline
quote:
ORIGINAL: 06sportster
Fly it as stock for a while...get the one that has motor/ESC/fan unit....you can always mod it later.
Now you did it!!!
Hide Signatures
(in reply to 06sportster)
       Post #: 218
RE: Phase 3 EF - 16 - 4/30/2009 10:02 PM
sanman55
Score: 100
Status: offline
Amen
Hide Signatures
       Post #: 219
RE: Phase 3 EF - 16 - 4/30/2009 10:52 PM
crashcrash
Score: 144
Status: offline
quote:
ORIGINAL: sanman55
Amen
Best to see if you can actually fly it before pumping $$$ into it.
Now you did it!!!
Hide Signatures
(in reply to sanman55)
       Post #: 220
RE: Phase 3 EF - 16 - 5/1/2009 4:55 AM
06sportster
Score: 100
Status: offline
quote:
ORIGINAL: crashcrash
quote:
ORIGINAL: sanman55
Amen
Thats probably good advice... I always seem to get carried away when starting something new. I did already have all the upgrades pick out and it all planned... I'm just waiting to see if I need to order a new receiver, or if I will be having one come available soon. I seem to have a magic number of plans that I can seem to keep all flight worth at a time...
Hide Signatures
       Post #: 221
RE: Phase 3 EF - 16 - 5/11/2009 7:35 PM
mk1spitfire
Score: 100
Status: offline
what speed for 4s 20w-20? fan size, blade count?
Hide Signatures
       Post #: 222
RE: Phase 3 EF - 16 - 5/26/2009 8:28 PM
gmair
Score: 100
Last Login: 5/26/2009
Status: offline
Just finished building  my second Phase 3. This one has a HET motor/fan unit in it and I"ll be using a 2650mah 4s lipo.
The stock Phase 3 came in at 25.4 oz. This latest one with the HET unit came in at 35 oz.
Just wondering if anyone has flown one at that weight, what it flys like and how much faster do you need to land.
Hide Signatures
(in reply to mk1spitfire)
       Post #: 223
RE: Phase 3 EF - 16 - 5/28/2009 2:34 PM
salmon
Score: 100
Last Login: 2/25/2010
Status: offline
Can anyone tell where to buy one of this jets , hobby people dont have it anymore
Hide Signatures
(in reply to gmair)
       Post #: 224
RE: Phase 3 EF - 16 - 5/28/2009 5:24 PM
wind junkie
Score: 100
Status: offline
Their web site says it is in stock now:
http://www.hobbypeople.net/gallery/107312.asp
Arguing with an engineer is like wrestling a pig. Everyone gets dirty and the pig likes it.
Hide Signatures
(in reply to salmon)
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
