Heli pic's
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Scale RC Helicopters >> Heli pic's Page: [1] 2   next >   >>
Login
Heli pic's - 8/12/2007 5:36:23 PM
Laurence Kemsley
Status: offline
Hi
I am just a beginner but want to move up in the world and go for big. I am only used to small helicopters(not electric)and I just want to see what the market has to offer, so just post your pictures and let me ask questions please
       Post #: 1
RE: Heli pic's - 8/15/2007 8:36:24 AM
antja
Status: offline
Hi
How about this for size
1/12 scale 1625mm long
(in reply to Laurence Kemsley)
       Post #: 2
RE: Heli pic's - 8/15/2007 3:40:12 PM
Laurence Kemsley
Status: offline
WOW!!! she is a beauty. How long did it take to get this far into the build? and what type of model is it?
(in reply to antja)
       Post #: 3
RE: Heli pic's - 8/15/2007 3:45:28 PM
soop7667
Status: offline
Here's one for ya - This is what happens if you zig when you're supposed to zag
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 4
RE: Heli pic's - 8/15/2007 5:09:51 PM
Laurence Kemsley
Status: offline
WO!! What happend there?
(in reply to soop7667)
       Post #: 5
RE: Heli pic's - 8/15/2007 6:19:40 PM
soop7667
Status: offline
Had no governor at the time, and had just programmed stunt modes. Didn't realize that on a Nitro Heli that the engine and headspeed would tach up so much when punching negative pitch while up-right (Non-Inverted) I knew what direction the heli was facing when it happened and judging from where the blade landed, and the crash damage sustained, I can conclude that when one of the blades was about 15 degrees past the tail boom, it pulled straight out from the blade grip, ripping the wood straight out of the blade boss. It sent the blade over 100 yards, directly in my direction, and the blade fell from the sky landing at my feet. The other blade, which was still attached to the head, and rotating continued in it's rotation twords the rear of the heli, at which time the extreme unbalance, and high head speed exerted such a great ammount of G-Force, that it literally broke the frame apart into three main sections. The main shaft, it's bearings, and the plastic portion of the frame that retained it came out in one piece, the tail boom and the portion of plastic that retained it was another piece, and the rest of the frame, along with the servo tray came out in another piece. The batteries mounted on the servo tray ripped off it's zip ties and rubber bands, as well as the two way tape. Multiple pieces of the head, linkages and other misc. parts came off / broke, the canopy flew off, and the engine raced at full throttle with no load on it until it burned up the fuel left in the lines. The main fuel tank ruptured, and the entire process took less than 1/10th of a second, all while about 50 feet off the deck. The parts were scattered across a 50 yard radius from the center of the incident in a field with very high grass and weeds. I spent an hour every day for the following week searching and collecting pieces. The only part I didn't find was my secondary receiver for the Spektrum AR7000. It took 4 months to get over it and buy replacement parts. At that time I promptly purchased a Throttle Jockey Pro Governor. I am currently waiting to receive my CF blades, and then I won't have to worry much about 2000 RPMs on the head. The pic of the heli together is right after I rebuilt it. I hadn't even put the blades on it yet. The three main causes were - Head Speed was too high, I didn't glue the blade bosses on, and I had no prior Nitro experience - (Ignorance)
If you look closely at the picture you may see a red circle at the end of the blade. This shows where it pulled the wood straight out.
I'm glad to say that now I'm very well schooled - too bad I had to learn the hard way, but she flies like a dream now - Just did my first loops last sunday.
       Post #: 6
RE: Heli pic's - 8/16/2007 11:55:37 AM
mrcandyman
Status: offline
I love the 4 and 5 blade setups. It's just so expensive for a part that really shouldn't be any more expensive than a normal one...
(in reply to antja)
       Post #: 7
RE: Heli pic's - 8/16/2007 3:04:50 PM
RodanAZ
Status: offline
Thunder Tiger MD530 on Raptor V2, redone in civilian colors:
Easy kit to build, though it's more of a sport scaler, as there's no room for a cockpit. However, you can still add a lot of scale detail and have a pretty impressive model. The other advantage is that it's relatively inexpensive, so it makes a good first scale ship, at least it did for me!
(in reply to mrcandyman)
       Post #: 8
RE: Heli pic's - 8/16/2007 3:18:57 PM
Laurence Kemsley
Status: offline
I know the feeling it happend to me once or twice.
       Post #: 9
RE: Heli pic's - 8/18/2007 6:16:05 AM
antja
Status: offline
Hi Laurence
Its an agusta EH101 1/12 scale took about 9 months to get to this stage
Tony
       Post #: 10
RE: Heli pic's - 8/18/2007 2:55:41 PM
Laurence Kemsley
Status: offline
Hi Antja
What mahe is it? what motor has it got? and if you can get more pictures on it then it would be great.
(in reply to antja)
       Post #: 11
RE: Heli pic's - 8/18/2007 2:56:45 PM
Laurence Kemsley
Status: offline
Sorry let me say that again.
What make is it? what motor has it got? and if you can get more pictures on it then it would be great.
       Post #: 12
RE: Heli pic's - 8/18/2007 5:23:43 PM
Don Perry
Status: offline
Here is my Bell 412,
More pics at www.rnlinc.com in the r/c gallery.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Don Perry - Altecare RC Sponsored Pilot
http://www.altecare.com/radiocontrol.htm
       Post #: 13
RE: Heli pic's - 8/18/2007 9:04:57 PM
blade_killer
Status: offline
that 412 is sweet!
Scott
(in reply to Don Perry)
       Post #: 14
RE: Heli pic's - 8/18/2007 10:40:52 PM
BarracudaHockey
Status: offline
Don that is absolutely georgous!
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to blade_killer)
       Post #: 15
RE: Heli pic's - 8/19/2007 12:24:03 AM
Don Perry
Status: offline
