RE: Brushed to Brushless conversion
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> RE: Brushed to Brushless conversion
Page: <<   < prev  1 [2]
Login
RE: Brushed to Brushless conversion - 8/17/2007 6:26:30 AM
DAL4215
Status: offline
How much do those run for? Im trying to spend as little as possible. So should the 10x4.5 work good?
(in reply to ADChobbystore)
       Post #: 26
RE: Brushed to Brushless conversion - 8/17/2007 7:59:51 PM
ADChobbystore
Status: offline
It depends, anywhere from $29-$50. Just do a search. Maybe start with towerhobbies. E-Flite has a PowerMeter but I think it is $45.
Just make sure it goes up to at least 40 amps minimum and measures, amps, watts, volts at least
< Message edited by fliprob17 -- 8/17/2007 8:00:31 PM >
_____________________________
"All About The WATTS!!!"
adchobbystore.com
(in reply to DAL4215)
       Post #: 27
RE: Brushed to Brushless conversion - 8/17/2007 10:08:23 PM
DAL4215
Status: offline
Ill just have to check my locol hobby store to see what they have. And what happens if the props dont counter rotate? And the more powerful motor that Dr kiwi mentioned is better than eflights BL450?
< Message edited by DAL4215 -- 8/18/2007 12:27:04 AM >
       Post #: 28
RE: Brushed to Brushless conversion - 8/18/2007 2:28:24 AM
Dr Kiwi
Status: offline
quote:
ORIGINAL: DAL4215
You don't HAVE to have counter-rotating props. There will be more torque reaction if the both spin the same way, but that need not be fatal.
I mention a $49 Dualsky motor which is fully capable of 200W (burst 250W) http://www.2dogrc.com/ecommerce/os/catalog/xmotor-3530ca14t-250w-glow-torque-p-2030.html
If you don't need that much the next size down is ~150W capable and less than $40.
The $65 E-flite 450 is barely a 150W motor since max continuous current is only 14A.
Dr Phil Millener, Chattanooga, TN
       Post #: 29
RE: Brushed to Brushless conversion - 8/18/2007 4:40:51 AM
DAL4215
Status: offline
I need a motor that can carry 936-1134 grams. (Eflight P-38) The manual says not to use anything more powerful than there motors (specs at horizon hobby model # EFLM1400) please help me find a motor very simular for a cheaper price. please. would the http://unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=4700 work for this plane? And ill need a 3 cell 2100 mAh LiPo pack any one know any cheap ones?
Thanks for helping me out guys
< Message edited by DAL4215 -- 8/18/2007 7:56:48 AM >
(in reply to Dr Kiwi)
       Post #: 30
RE: Brushed to Brushless conversion - 8/18/2007 4:21:59 PM
Dr Kiwi
Status: offline
That KDA A20-22L would be fine. With 9x5 GWS HD props you'd get ~750g per motor from 130W each (just over 12A each on 3s) - If you go with a 3s 2100 you will need at least 15C, since you'll be drawing 24A total.
< Message edited by Dr Kiwi -- 8/18/2007 4:30:08 PM >
       Post #: 31
RE: Brushed to Brushless conversion - 8/18/2007 9:54:32 PM
DAL4215
Status: offline
Now when you say 15C what are you referring to? And do you know of any 9x5 counter rotating props? What would happen if i get a 9x5 pusher prop?
< Message edited by DAL4215 -- 8/18/2007 10:08:48 PM >
       Post #: 32
RE: Brushed to Brushless conversion - 8/20/2007 6:03:14 AM
DAL4215
Status: offline
Any one know if its possible to do retracts on this plane?? And flaps?? And if so where? And How?
< Message edited by DAL4215 -- 8/20/2007 6:07:58 AM >
       Post #: 33
RE: Brushed to Brushless conversion - 8/20/2007 2:14:14 PM
ADChobbystore
Status: offline
quote:
ORIGINAL: DAL4215
15C is the battery current rating. A 2100mah 15C battery can handle 31.5amps. You take the 2100 and divide by 1000 to take the miliamps to amps. So 2.1, then multiply by the C rating number, in this case 15. So 2.1amps x 15C = 31.5amps.
Pusher props are designed for rear/mid. motor mounted planes in which the motor is turned around and mounted backwards, facing the rear of the plane If that makes sense. They are designed to push air instead of pull it, like a normal motor mounted setup would.
adchobbystore.com
       Post #: 34
RE: Brushed to Brushless conversion - 8/20/2007 3:55:30 PM
DAL4215
Status: offline
But on the pusher cant you turn the direction of the motor and have it spin to grab the air??
       Post #: 35
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU5
