Tweedybird
NJ, USA Status: offline
quote:
ORIGINAL: vnmsgt Here are some pics of my build I am doing. So far its been confusing . They give you a couple different pieces of the same parts on alot of stuff that change suspension setting and stuff like the hingepin holders and where the front knuckle bolt to that you do not know which ones to use. I have been looking at the team driver set up sheets and trying to go buy that to get a good baseline. I do have a question though. What's up with the second set front UPPER arms? They are shorter and do not look the same. Looking great Vnmsgt, Keep us updated. I only have 3 diffs started on the whole build lol, not even finished diffs, started lol. waiting on a few major shipments before I can begin really getting down in the build. will post pics when theres something worth snapping. TB BTW ProRC more dirt acumulates in the front of your motor and you don't want dirt to get into a ceramic bearing. rubber sealed or not dirt will get in eventually. regardless, I change my motor bearings every gallon, and the rest are usually changed at the end of every race season.
_____________________________
Run Your Engine, Don't Let Your Engine Run You! *Love the smell of Nitro in the morning!* -=RCUniverse.Com=- When the cop pulls you over doing 160 mph, and asks if you knew how fast you were going say, "yep i had cruise control on".
