Tweedybird
NJ, USA Status: offline
quote:
ORIGINAL: nascardad24 Not to sure. I know if you run the ofna flywheel then youll need the ofna bell, or the kyosho flywheel set up the the kyosho bell. Reckward might be able to run any bell, not sure. Just make sure you have an extra set of shoes, most tracks or hobby shops dont carry those on hand but can order them. I tried a mugen set up on the kyosho and it didnt work, the teeth on the bell didnt sit right with the spur, it was a bit off line. Only have the bells teeth hit the spur. What ever make of bell you get go with the vented ones. They run cooler and save extra wear on the shoes and bearings. Check Reckwards web site, see what the recomend running with their set up. Yeah Nas, Reckward has there own bells 13 and 14T vented. Maybe I should get both, depending on setup needs at the track. the initial clutch comes with black carbon shoes, but I'm unsure of the size of the shoes. I'd rather have alumi shoes, but I can use the stock carbon shoes for break in then check them once I have a gallon in the mill. and keep the alumi's on the side just in case. all reckward parts listed on amain just do a product search for Recward. Let me know what size shoes I need with that speed 3 if you can. Thanks TB
_____________________________
Run Your Engine, Don't Let Your Engine Run You! *Love the smell of Nitro in the morning!* -=RCUniverse.Com=- When the cop pulls you over doing 160 mph, and asks if you knew how fast you were going say, "yep i had cruise control on".
