ProRCRacer88
VA, USA Status: offline
Yesterday me, pklot, and 2 other guys went to a BMX track. I said earlier in this thread that i was having high temp problems with the RB. So i decided before I change anything i would use a different temp gun, turns out my temp sensor is off by 40F and the truck was running between 160 and 200F. Very glad to see that was the case so i will need to recalibrate my temp feature on the control. We had to wait for about a half hour for the BMX guys to finish but after then we really got to run. We basically practiced the jumps yesterday. I got mines warmed up and jumped a few times, at first i was messing up but shortly after, i became a pro with it. The st-rr flys so nice and level in the air and will land on all 4s everytime. You dont have to be a Pro driver to clear jumps with this thing. My highlights of yesterday was when i went off the middle of the bowl where one of the turns is. I went about half throttle off the top and got the truck at least 10ft off the ground and flew 20ft before landing perfectly on all 4s. The other was when i got on the track and cleared those big triples, which isnt as easy as i it looked to be. My drive time ended after about 4-6 tanks when the rx battery went dead. The last time i charged it was at least 30 days ago, so it held a charge more than long enough for me to get about 16 tanks through the RB in all. I run the Balistics 5 cell pack, those rx packs last for ever on a charge, id recommend it to anyone. Even though i had a few bad landings, the only damage done was a few missing screws that hold the top part of the wing mount together. The engines power is another thing, i ran it using no more than half throttle and they way it was running you would think I was WOT, it its not even half way in tune as it could be. Im waiting on seeing what it will do once i get a full gal. through it. Pklot''s st-rr with his modded OS28 was very impressive to me. That thing will be a handful and then some to try and control on a track.
< Message edited by ProRCRacer88 -- 4/14/2008 7:34:12 PM >
_____________________________
-Wolf Fusion, Kyosho ST-RR, Kyosho 777 WC
