gtsum
VA, USA Status: offline
quote:
ORIGINAL: ProRCRacer88 Dont spend that kind of money on that. OS engines that are modded run the same as a stock RB thats detuned. I believe they are overpriced by far. Plus they arent part of a winning setup on any car or truck I seen.. you surely are not serious, are you?? OS Engines have won countless world championships and local races all over the world. Before you think I am an OS homer, I do NOT run an OS (have in the past) - I run GRP and Nova engines, but OS mills are tough to beat...they tune like no other engine (easier), they hold a tune, and they have plenty of power and not many engines get the same kind of runtime the OS's do (10 minutes plus). The vspec cannot be touched for 275, and the Speed, while pricey, is downright fast on the track..I have seen several OS Speeds obliterate C6's down a long back stretch. The only issue that I can see with OS is the longevity (bearing failures in the past, rod wear, etc), and I fully believe that a good Italian engine (RB, Nova, GRP, etc) will far outlast an OS engine (which is why I run them), but the OS's are a good mill
