gtsum
VA, USA Status: offline
quote:
ORIGINAL: pklotking Hey 88 I did good on the track this past week end but I don't think I'm ready for a race. hey gtsum did you go yo the money race this past wekend in glousterif so who did you do yep, I was there...my first qualifier was very good...I ran 9 laps in 5:29 - I had 2 bobbles that cost me a 5:20 or so, but that was about as good as I could have done...as it was I was 7th qualifer (2nd-7th place was separated by 9 seconds over 5 minutes, so the racing was tight). I got a good start in the A main and was running 3rd when my GRP went lean (bad) and then cut off...got it back to the pits and noticed that the fuel line was cut, so got that fixed and back on the track...I was a couple laps down, but 9 minutes later when I pitted I was in 4th...things were going well, but then my brakes went out and it acted lean again (****???)...it cut off again and brought it back in to the pits and noticed that the fuel tank lid did not get closed all the way (the fuel line was caught under the cap)....at this point, the entire chassis was soaked with fuel, the air filter was soaked, etc, so I called it quits. If that pit mishap did not happen (it was my fault though for running the fuel line like I did), I likely would have gotten 2nd, but that is racing. I did manage a 34.3 second lap, which I think was the 3rd or 4th fastest truggy lap of everyone running, so the truck is definately fast (much faster then my last ride). Hkenvy91 put a new setup on his and it did not quite agree with him, but he tuned the truck in again and got a backup motor running pretty good and made some good laps and outlasted a lot of the field and took 4th I think... anyone in the area (richmond, etc) should head out there on a sunday. There is a sportsman class that you can race in (until you get too fast!) that way there no pressure from the fast guys, etc. It is the only way to learn to run a track and race (if that is what you like)...cuz there is a big, big difference from standing on the track running by yourself compared to being on the stand with 9 other truggies on the track....plus, the only way to get better and faster is to race against faster people! Hope to see some of you out there!
