RE: - Official Kyosho MP777 ST-R Thread -
Tower Hobbies
Logged in as Guest
  Printable Version
HPI Racing Baja 5B - RTR
Seller:  lisa2803
Details:   $799.99   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: - Official Kyosho MP777 ST-R Thread -
Page: <<   < prev  37 38 [39] 40 41 42 43 44 45 46   next >   >>
Login
RE: - Official Kyosho MP777 ST-R Thre... - 6/7/2008 5:00:56 PM
ProRCRacer88
Status: offline
For some strange reason, the right side front steering knuckles keep getting stripped out on the bottom. Im pissed now because those CNC knuckles are so expensive and i strip one of those out like i do the cheap standard knuckles. There has got to be some kind of problem with that side of my truck because i dont never have any other problem except that 1 knuckle (unless i do something stupid). Has anyone else had any kinds of problems when they upgraded the knuckles or is it just me being the unlucky one? Can i retap it and be good to go or will it never be the same and need replacing? For now i had to put the cheap one on in its place.
Its going to be 100+ outside all weekend.
_____________________________
-Wolf Fusion, Kyosho ST-RR
(in reply to will13)
       Post #: 951
RE: - Official Kyosho MP777 ST-R Thr... - 6/7/2008 5:02:37 PM
ProRCRacer88
Status: offline
WB TB, good to hear you finally got to run the truck hard.
(in reply to ProRCRacer88)
       Post #: 952
RE: - Official Kyosho MP777 ST-R Thr... - 6/7/2008 5:58:04 PM
ProRCRacer88
Status: offline
       Post #: 953
RE: - Official Kyosho MP777 ST-R Thr... - 6/8/2008 12:42:39 AM
nascardad24
Status: offline
Dang pro, thats ruff. If you didnt take the threads out of the inside of the knuckles you might be able to just rethread the screw in and save the threads that are still good. If you retap it, your maken the hole bigger and would need to use a larger screw, not sure a larger screw will fit into the collar bushing. Might be able to just tap it with the same size screw though, I would try that first.
Kyosho STRR~Futaba~Sirio~Acer Racing~BCE~
Horsepower sells engines, Torque wins races
       Post #: 954
RE: - Official Kyosho MP777 ST-R Thr... - 6/8/2008 12:52:56 AM
nascardad24
Status: offline
The latest strr body Ive painted up. Think I'll run this for the pro series events.
(in reply to nascardad24)
       Post #: 955
RE: - Official Kyosho MP777 ST-R Thr... - 6/8/2008 1:07:39 AM
gtsum
Status: offline
Pro - did it strip out when you tried taking it off? If so, next time you go to take it off, heat it up with a heat gun to break the bond of the threadlock. I have heard of a LOT of people stripping those out if they do not use a heat gun
       Post #: 956
RE: - Official Kyosho MP777 ST-R Thr... - 6/8/2008 1:20:14 AM
hkenvy91
Status: offline
now thats upping the bling bling factor there!
kyosho strr,airtronics M8,o.s.speed,jp-3,tilted fuel
       Post #: 957
RE: - Official Kyosho MP777 ST-R Thr... - 6/8/2008 2:04:22 AM
ProRCRacer88
Status: offline
I never seen a body like that, thats definatly going to shine out on the track.
Nascar, I see that it wont work if i tap the hole bigger. Its stripped so when i go to put the screw in, over half the screw slides in and theres only a few threads left on the inner part. When i try to tighten it it just spins.
Gtsum, it stripped itself while i was running the truck, and at the time i didnt have thread lock on it.
(in reply to hkenvy91)
       Post #: 958
RE: - Official Kyosho MP777 ST-R Thr... - 6/8/2008 2:20:34 AM
hkenvy91
Status: offline
well i myself are still runnin the cast hubs with no issues at all!
so tell me guys!, whats wrong with this picture?
Click to see fullsize image.
Click for fullsize
< Message edited by hkenvy91 -- 6/8/2008 2:21:41 AM >
       Post #: 959
RE: - Official Kyosho MP777 ST-R Thr... - 6/8/2008 2:23:47 AM
hkenvy91
Status: offline
its killin me waiting for this new mill to get here.its been almost a month now that my old one went pop.my new secret weapon will be here this week hopefully!
all i know is for 400 bucks , i better get 10 gallons out of it
< Message edited by hkenvy91 -- 6/8/2008 2:27:32 AM >
       Post #: 960
RE: - Official Kyosho MP777 ST-R Thr... - 6/8/2008 3:40:36 AM
ProRCRacer88
Status: offline
Who makes that engine in the pic? never seen it before. im guessing its a nova or the os speed.
       Post #: 961
RE: - Official Kyosho MP777 ST-R Thr... - 6/8/2008 4:38:32 AM
hkenvy91
Status: offline
speed
       Post #: 962
RE: - Official Kyosho MP777 ST-R Thr... - 6/9/2008 6:53:44 AM
Shark413
Status: offline
ProRCRacer88, I also had the CNC knuckles strip out. It's been a while so I can't remember which side it was, but I do know it was the bottom screw. I had loctite on the screw (blue) and it still backed out, which is what caused it to strip out. The screw backed out and had about 1 or 2 mm of screw still in the knuckle, then a hard hit or landing just pulled the screw right out of the knuckle, stripping that 1 or 2mm of thread out of the knuckle.
http://www.youtube.com/watch?v=QnwpWq7kynA
ST-RR in action
< Message edited by Shark413 -- 6/9/2008 6:55:04 AM >
Kyosho ST-RR Brushless / Kyosho Kanai III Brushless / Jammin CRT.5 Brushless / E-Revo
       Post #: 963
RE: - Official Kyosho MP777 ST-R Thr... - 6/9/2008 6:52:41 PM
ProRCRacer88
Status: offline
Nice clean run there Shark. So when it stripped out what did you replace it with? Im thinking its no use to me no more because i can put a bigger screw in and if i stripped out the first time for no reason then it will definatly do it again even if i tap the threads. I probably will have to try the kingheadz knuckles soon or later.
(in reply to Shark413)
       Post #: 964
RE: - Official Kyosho MP777 ST-R Thr... - 6/9/2008 7:22:32 PM
jusleanit
Status: offline
wheres the pic?? os speed ?? nice choice
nice lid nascar
< Message edited by jusleanit -- 6/9/2008 7:23:57 PM >
REVO O.S. 18TZ, MBX5T-Prospec O.S.28(AB Mod Stage2)
       Post #: 965
RE: - Official Kyosho MP777 ST-R Thr... - 6/9/2008 8:38:08 PM
nascardad24
Status: offline
Hey Pro, this just hit me, you could use a longer screw, insert it through the bottom of the knuckle and then through the steering rod and fasten it with a nut. That will save the cost of another 70 dollar knuckle set.
Thanks jusleanit, lots of chrome paint was used. Headed out for some pics with it on the truggy.
(in reply to jusleanit)
