123Splat
Joined: 4/27/2007 From: Austin, TX, USA Status: offline
DK, Are you SURE about the blade grips? Double check. Don't get pissed if I get too elementry here, just to be sure. Leading edge is the thick part, trailing edge is th thin part. Holding the bird straight out in front of you, the leading should be facing you on the right, the trailing edge should be facing you on the left. The grip on the right should have the ball joint away from you, the grip on the left should have the ball towards you. if you move the flybar, the pitch should change on both blades. If that works, unplug one of the main motor leads, turn on the xmittr, connect the flight battery, hold the tail boom steady, work the collective(or is it the cyclic? them technical terms always confuse me) in all four axies (forward, right, aftward, left) to make sure you get correct response in all four, then run up the throttle and look for pitch change as throttle increases ( no yaw input, left or right tail). If you got the blade assembly and the hub correct (with the grips oriented correctly, remember that the picture in the 'Manual' is incorrect), the only thing that comes to mind is: 1) maybe you compressed one or more of the linkages (Plastic ballreciever on metal threads, the ball reciever threads can be forced in or out on the metal rod with enough force. Check blade tracking and response of the rotor disk under load (hold the birg, by the landing struts (or better yet, if you have a test jig use that), out in front of you (with the main motor plugged back in), slowly run the throttle up a little, do the above checks, run the throttle up alittle more and check again, and so on. If that doesn't help you find the prob, I'm stuck, unless you have damaged the 3-in-1 board. Oh, by the way: I had a hard landing (didn't seem to do any damage), but I couldn't get her to lift off after. Investigation revealed that the hard bounce had managed to jam the main motor into the main gear. Too much drag from tension, I couldn't get enough power to lift off. Tore her down and repositioned the main motor. Everything was alright after that. Wish I could be of more help! Good Luck, Splat
< Message edited by 123Splat -- 8/13/2007 4:17:09 PM >
_____________________________
It's not the takeoff or the flying, it's the landing and repairing, so I can takeoff and fly again...
