Two .46 engines... what size plane?
Tower Hobbies
Logged in as Guest
  Printable Version
Top Flite Cessna 310 - ARF
Seller:  Jerryballs
Details:   $1,200.00   |  6/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> Two .46 engines... what size plane?
Page: [1]
Login
Two .46 engines... what size plane? - 8/13/2007 6:24:42 AM
jacobezzell
Status: offline
I have one OS LA 46, working on getting another. would these be crazy to strap to an LT-40 kitbashed to a twin with a beefed up wing? Would the extra weight required balance things out?
       Post #: 1
RE: Two .46 engines... what size plane? - 8/13/2007 3:04:28 PM
wingspar
Status: offline
Not only the wing but the tail and rudder as well. Don't know why you would want to put that much power in a plane the was designed to be a easy to fly trainer. You would be better off installing a pair of .25 engines.
Dave
(in reply to jacobezzell)
       Post #: 2
RE: Two .46 engines... what size plane? - 8/13/2007 3:12:20 PM
jacobezzell
Status: offline
Well, honestly because I'm just trying to work with the engines I have... If there is a slightly larger kit I should try, please let me know.
(in reply to wingspar)
       Post #: 3
RE: Two .46 engines... what size plane? - 8/13/2007 3:54:44 PM
wingspar
Status: offline
Here are a few suggestions:
Nitro Models Cessna 337 SkyMaster
Horison Hobbies Dual Ace
Hanger 9 B-25
I'm sure there are lots others
Dave
       Post #: 4
RE: Two .46 engines... what size plane? - 8/13/2007 4:01:51 PM
jacobezzell
Status: offline
These are all twin ARFs, I want to build something, and not a fancy warbird kit... Thats why I wanted to kitbash the LT-40.
       Post #: 5
RE: Two .46 engines... what size plane? - 8/13/2007 4:10:39 PM
wingspar
Status: offline
No ARF's? OK
How about a Top Flite DC-3?
       Post #: 6
RE: Two .46 engines... what size plane? - 8/13/2007 4:30:23 PM
jacobezzell
Status: offline
Maybe, that looks like a beautiful kit, BUT I was hoping to bash something together so I'd have a cheap plane to play with, try out a twin, and get to custom build some stuff. Oh, and I'm halfway through building my second plane. I have a LT-40 in the trash (trainer crashed me grumble grumble.) I'm building a 4 star 60, and have a hog bipe to build too.
< Message edited by jacobezzell -- 8/13/2007 4:38:29 PM >
       Post #: 7
RE: Two .46 engines... what size plane? - 8/13/2007 4:30:55 PM
evan-RCU
Status: offline
Buy two .40 size airplanes and bash them like this; The second pic is another overpowered trainer.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Revver #125, Pico Owners Club #3
       Post #: 8
RE: Two .46 engines... what size plane? - 8/13/2007 4:56:24 PM
jrf
Status: offline
Why not do the twin conversion of the Hobbistar 60 that is in the current issue of Model Aviation magazine. It will take two 46's and, with it's 71" semi-symmetrical wing, it will handle the power a lot better than the LT 40.
Jim
(in reply to evan-RCU)
       Post #: 9
RE: Two .46 engines... what size plane? - 8/13/2007 5:03:51 PM
jacobezzell
Status: offline
I saw that, I just would rather do a kit than mess with an ARF. That way when I crash I've already had 100 hours of fun.
(in reply to jrf)
       Post #: 10
RE: Two .46 engines... what size plane? - 8/13/2007 5:22:39 PM
jrf
Status: offline
Kit bash your 4* 60 into a twin for the two 46's. That would be a great combo! If it's too late to bash the one you're building, use the plans to build another one.
Jim
       Post #: 11
RE: Two .46 engines... what size plane? - 8/13/2007 5:39:24 PM
jacobezzell
Status: offline
That would be sweet, maybe I'll build another after this one... I havn't started on the wing yet, but I have the fuse finished and set up for a Saito 91 FS. It would be nice to have one already built to be able to take plans off of for building the nacelles... Thanks for the idea!
(in reply to jrf)
       Post #: 12
RE: Two .46 engines... what size plane? - 8/13/2007 7:19:03 PM
Edwin
Status: offline
How about an ugly stick design. You can design and build it from your head. Easy access to the engines. Quick build, easy to repair, and can be tons of fun. Can even easily put in a bomb drop.
Edwin
       Post #: 13
RE: Two .46 engines... what size plane? - 8/14/2007 1:51:36 AM
Ed_Moorman
Status: offline
I think the LT-40 will be fine. I have a pair of OS .46LAs on a twin and they aren't going to pull the wings off unless you start doing crazy things which would probably kill the plane on a single engine. You are talking ball bearing .32 power here. I like a 10-7 or 11-5 prop.
I would strengthen the center wing and add some bracing wires on the tail. If you get the CG right, I'd use weed eater line. I use that a lot on planes. It weighs next to nothing and will keep your tail from breaking. If the plane is nose heavy, I'd use 2-56 rods just for the extra weight.
On the LT-40 with extra power, you'll need to shim up the trailing edge of the wing. I would jack it up 2 popsicle sticks or about 3/16". This should keep the plane from climbing at full power.
Ed Moorman, AMA 553, KD4QBM, Revver Bro #156
R/C Report Magazine, Fun Aerobatics Column
(in reply to Edwin)
       Post #: 14
RE: Two .46 engines... what size plane? - 8/14/2007 2:52:19 AM
octane-link
Status: offline
Goldberg makes a .60 size trainer kit that I am thinking about kit bashing into a Twin Otter, that size should take two .46's easily enough.
Aerospace Engineer
UAV Builder
(in reply to Ed_Moorman)
