RE: Why you love the OMP Fusion?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Why you love the OMP Fusion?
Page: <<   < prev  5 6 7 8 9 10 [11] 12 13 14   next >   >>
Login
RE: Why you love the OMP Fusion? - 5/13/2008 11:22:39 PM
Gringo Flyer
Status: offline
Started on the build yesterday. I decided to start with the wings because generally that is my least favorite part of building. The first wing half has gone together well and I really like how its built.
After framing it up the wing is almost impossible to flex. I think we all have had headaches when a wing torques a bit when the covering shrinks but this wing is solid. Its also super easy to build straight.
So far 2 thumbs up on the build.
One thing I dont undestand is on the bottom of the wing why is the inner bay sheeted, the second bay open, and then the third bay sheeted? Is it just to give the covering a good frame to stick to around the servo? It seems like the frame you make for the servo would be enough.
Not a big deal, just curious, this is the first plane I have seen with the sheeting that way.
_____________________________
"Courage is being scared to death...and saddling up anyway."---John Wayne
(in reply to Constrictor)
       Post #: 251
RE: Why you love the OMP Fusion? - 5/14/2008 2:26:06 AM
AFSalmon
Status: offline
Good questions Gringo. The reason the root bay is sheeted is to add strength to this most important bay. The root bay has the most stress and loads and tying the R1 and R2 ribs together forms a box sort of which greatly adds to the overall strength. The servo bay is sheeted also to add rigidity to this bay as all the aileron aero-loads will be transferred through the pushrod to the servo. In other words if you have a 100 in-oz torque servo in there then the servo mount and surrounding structure need to handle 100 oz of force. Hope this helps.
Mike
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to Gringo Flyer)
       Post #: 252
RE: Why you love the OMP Fusion? - 5/15/2008 2:16:38 PM
MIXMASTER
Status: offline
My Fusion is the only glow plane that gets flown lately, I'm getting the hang of it, almost got a hovering circle going. I tilt it to HA KE & then use elev to steer it around,lots of fun, I finally got several hovering tail touches in too. One thing, I dont see how Spacey could hold the plane for a hand launch, I like to do that sort of stuff too but its too weak in the canopy area, it crushes the frame, I wonder if he built it up in that area?
Jimmy touch tail & I dont care!!!
(in reply to AFSalmon)
       Post #: 253
RE: Why you love the OMP Fusion? - 5/15/2008 2:32:31 PM
Spacey
Status: offline
Three thoughts:
Please don't try what I did in the video at home kids! It's stupid and should only be done by people who live in wild africa who's lives are worth less than a cheap cell phone. It's dangerous and irrisponsible. (Sorry I'm trying to quit smoking...really...it's going tough).
My bird's not an ARF, go check out the beginning of the thread. The kit has a foam core fus.
And then lastly, when you got a hold of the bird like that it's still hanging from the prop. Your hand is just stabilizing it, my advice though is to never just shut the throttle when you catch a plane like that. They do tend to get rather heavy rather quickly that way. Bwhahahah
(in reply to MIXMASTER)
       Post #: 254
RE: Why you love the OMP Fusion? - 5/15/2008 2:45:16 PM
MIXMASTER
Status: offline
It was a good guess, I was thinking of it, it is a cool thing to do, I did it a few times with a Su-Do_Khoi. Then I left a mix on(elev-flap) and hand launched it, when I pulled up it came over the top and right at me, scared the bejesus out of me & a buddy too! Havent done it since but the Fusion makes me want to give it another go, I could cut some covering & add some hard balsa or even CF to the "Handle". mmmmmmmmmm?
(in reply to Spacey)
       Post #: 255
RE: Why you love the OMP Fusion? - 5/15/2008 2:56:10 PM
daveopam
Status: offline
I don't catch mine but have hand launched it. The canopy area will crack if you grab it wrong. I gently pick it up level and use the engine power rotate it. At this point like Spacey said your hand is holding it in place. Then just let it go. One other thing. It is always blowing here. Let it go with the wind to your back. This will blow it away from you.
Also like Spacey said. This is not the safest thing to do. If you do not have 100% confidence in your skills and equipment. Don't try this.
David
"Choose your shirt and shoes by the color. Choose your friends by their character." unknown
       Post #: 256
RE: Why you love the OMP Fusion? - 5/15/2008 3:04:14 PM
MIXMASTER
Status: offline
Yep, thats the safest way to do it, downwind & at a slight angle away from you, if the throtlle is just right, it will not fall but gently climb away, or you can go full to let it rocket up straight. I was thinking it would be a great way to start a close in hover.
(in reply to daveopam)
       Post #: 257
RE: Why you love the OMP Fusion? - 5/20/2008 3:09:43 AM
skyhawk73
Status: offline
I strapped a 14 oz Tetra bladder tank on with the piano wire and rubber bands. Worked like a charm. No more bubble problems.
However, I did notice that my Saito 125 made short work of the 14 oz. Maybe the bladder holds less than expected or 14 oz. just
ain't enough for a satisfactory flight time.
Also, I noticed a little fuel accumulated outside the bladder after six flights. Maybe I'm getting blowback residue from the muffler line.
Also noticed the hastle of filling without a tanker surrenge. Ordered a tanker surrenge from Jett to help facilitate fueling. Seems
Jett only sells a 11oz tanker surrenge.???
I could use allot more than six minute flights.
I'm thinking the Saito 125 is too much engine - a two stroker might not vibrate as much and might not be as thursty as a four stroker.
I'll see how I feel after twenty more flights.
BTW - filling the nose with guirilla glue and painting clear finger nail polish on the stripes had no negative consequences.
       Post #: 258
RE: Why you love the OMP Fusion? - 5/31/2008 1:29:59 AM
grnd0
Status: offline
Just put the first flights on my arf Fusion with an O.S.120AX. It ROCKS......
I had so much fun even with the brand new 120 and winds around 15mph.
It does everything so good. Only thing I couldn't get dialed in was flat
spins. Maybe too much elevator throw. Best HAKE' er ever. This thing
was made to knife edge. All the covering was still on too after 5 flights.
One more thing that made me real happy, I can get it my Venture van
in one piece.
Larry
(in reply to skyhawk73)
       Post #: 259
RE: Why you love the OMP Fusion? - 5/31/2008 3:51:51 PM
daveopam
Status: offline
Larry, try a few pinwheels. Go up into a hover give full right rudder and full power at the same time.
David
(in reply to grnd0)
       Post #: 260
RE: Why you love the OMP Fusion? - 5/31/2008 10:50:46 PM
Ernie Misner
Status: offline
Okay, slight change here, sorry, but what does everyone think of the 40 size Fusion compared to newer offerings??? (I have a 55AX lookin' for a new home....)
Ernie
       Post #: 261
RE: Why you love the OMP Fusion? - 6/1/2008 2:12:26 AM
grnd0
Status: offline
I have the Fusion52 with a Saito 82. Flies great but nothing like
the 67". I just put five more flights on the 67 and it's my new
favorite plane....
Larry
(in reply to Ernie Misner)
       Post #: 262
RE: Why you love the OMP Fusion? - 6/1/2008 12:26:00 PM
bikermonkey
Status: offline
For you gurus who fly the fusion, I have three engines, Saito 63, Saito 82 and Saito 115,, I want a Fusion, so which one would be best considering the power plants I have.
(in reply to grnd0)
       Post #: 263
RE: Why you love the OMP Fusion? - 6/1/2008 1:23:25 PM
grnd0
Status: offline
The 67 incher with the Saito 115 if you're not too high in
elevation. The bigger Fusion is a better flier. I like my
profiles to be user friendly and was real happy it fit in
my van in one piece. Assembly would be worse than my
big gassers at the field. That may be a deciding factor
for some people.
Larry
(in reply to bikermonkey)
       Post #: 264
RE: Why you love the OMP Fusion? - 6/2/2008 3:44:55 AM
skyhawk73
Status: offline
Fifteenth flight with a Fusion 90 witha Saito 125. I thought it was fun then let
our clubs TopGun fly it. He said it was the best flying 3D airplane he's flown.
I'm still experimenting with the bubbless bladder tank. It works great but
fuel management is frustrating compared to conventional configurations. However,
I like the bubblefree feature of the Tetra and Jett Bubbless tanks. I fly less distracted
without bubbles and missfires.
Still testing the Fusion 90 limits and character,
Sky
(in reply to grnd0)
       Post #: 265
RE: Why you love the OMP Fusion? - 6/2/2008 6:17:24 AM
Ernie Misner
Status: offline
Hi Skyhawk, what prop and fuel on that 125?
Ernie
       Post #: 266
RE: Why you love the OMP Fusion? - 6/2/2008 2:29:21 PM
AFSalmon
Status: offline
quote:
ORIGINAL: skyhawk73
