RE: Why you love the OMP Fusion?
Tower Hobbies
Logged in as Guest
  Printable Version
50 Size 3D Profile - RTF
Seller:  DAVIS300
Details:   $275.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Why you love the OMP Fusion?
Page: <<   < prev  5 6 7 8 9 10 11 12 [13] 14   next >   >>
Login
RE: Why you love the OMP Fusion? - 8/4/2008 3:40:28 AM
daveopam
Status: offline
You could put a set screw in the wing tube. Epoxy a small piece of thin ply on the portion of the wing tube you can see through the hatch. With the wings bolted on drill a small hole through the ply and one part of the tube. Then pull it apart and tapp the hole in the wing tube. Other than that you need to put a hole in the wing. It may be a good idea anyway. If there is going to be a piece of balsa banging around in the wing all the time. I would put a hole in it and fix it right. If not you will find small pieces of balsa start showing up between the covering and the wood.
David
_____________________________
"Choose your shirt and shoes by the color. Choose your friends by their character." unknown
(in reply to Gringo Flyer)
       Post #: 301
RE: Why you love the OMP Fusion? - 8/5/2008 10:52:49 AM
Spacey
Status: offline
Wouldn't it be easier to just cut a small hole in the covering so one can re-glue the stopper in place and just patch up the hole afterwards?
(in reply to daveopam)
       Post #: 302
RE: Why you love the OMP Fusion? - 8/5/2008 2:30:32 PM
Gringo Flyer
Status: offline
The piece of balsa feel out through the ribs. I just finished covering the wing so I am determined not to cut a hole in it. The stop screw is an idea.
"Courage is being scared to death...and saddling up anyway."---John Wayne
(in reply to Spacey)
       Post #: 303
RE: Why you love the OMP Fusion? - 8/5/2008 3:08:24 PM
sodbuster 1
Status: online
Mike you have any all white Fusion 67" arf's in stock at this time?
In reading the thread it almost seems like you don't
Once you go Yak, you never go back......
Club Saito member # 610
       Post #: 304
RE: Why you love the OMP Fusion? - 8/5/2008 7:40:44 PM
AFSalmon
Status: offline
quote:
ORIGINAL: sodbuster 1
Nope, all gone. Sorry.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to sodbuster 1)
       Post #: 305
RE: Why you love the OMP Fusion? - 8/6/2008 1:58:28 AM
ARTP47
Status: offline
Lost my Fusion to day, to a striped Hitec 475 aileron servo. It was by far the best airplane I have ever had. Moral of the story don't send econo servos to do a mans job! Next Fusion will get better gear.
       Post #: 306
RE: Why you love the OMP Fusion? - 8/7/2008 9:20:45 PM
sodbuster 1
Status: online
quote:
ORIGINAL: AFSalmon
ok, when then?
Noticed in the thread you mentioned something about improvements if I'm not mistaken.
What would they be if any
(in reply to AFSalmon)
       Post #: 307
RE: Why you love the OMP Fusion? - 8/8/2008 3:04:37 AM
steve51
Status: offline
Lost my Fusion last night after 3 flights, the left aileron came off in straight and level flight at half throttle. I found the hinge slots on the wing trailing edge to be tapered which let the CA hinge glue only a 1/16th of an inch of the trailing edge. Checked the right wing and the same thing, make sure you check those hinges so they are tight in the slot next time I'll make sure they are pinned.
The plane was rock solid and a great performer with a YS 45 on it.
       Post #: 308
RE: Why you love the OMP Fusion? - 8/8/2008 2:50:12 PM
AFSalmon
Status: offline
quote:
ORIGINAL: AFSalmon
ok, when then?
I routinely improve models from cycle to cycle. I'm working on an improved fuselage construction technique and some other minor construction changes. The basic Fusion outline will remain the same as it is already perfect.
       Post #: 309
RE: Why you love the OMP Fusion? - 8/10/2008 11:57:21 PM
Gringo Flyer
Status: offline
Finally maidened the Fusion today. My setup is
Saito 125
All Hitec digital coreless servos Elevator 6975, Rudder 6965, Ailerons 5925MG
6 volt 1500mah battery
CG is per recomendation in the manual.
Prop MA 16X6
White and orange are oracover and trim is in monokote applied with the windex method. I had a bunch of leftover monokote so I put it to good use, 10 different colors on this plane!
Here are some pics
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Gringo Flyer -- 8/11/2008 12:08:07 AM >
       Post #: 310
RE: Why you love the OMP Fusion? - 8/11/2008 12:06:47 AM
Gringo Flyer
Status: offline
My maiden went really well today. This is an amazing plane. I knew it would fly well from all that I had read about it, but it goes beyond that.
I have a 90 size pattern ship, several 40-90 size 3D planes and the Fusion flies better than all of them at 3D or pattern. Knife edge is amazing it just sticks there. Knife edge loops are so tight its unbelievable. Part of this could be the servos as its the first plane I have with high end servos but performance is awesome on this bird.
It has tons of power but not the rocket out of a hover power that I expected. I expected a little more juice out of the saito. It only has a little less than a gallon through it and I am still running it rich so hopefully it will get better. Transition is great on the engine. It easily idles at 1900 and instantly accelerates to WOT.
One potential problem that I wonder if anyone else is having. Do you have any problem with fuel spray from the carb working its way into the space between the wing and fuse? I am still running rich and my plane was completely slimed but I wonder about long term oil seaping into that area.
Overall all its a winner and I will end up ordering a kit just to save in case something happens ot this one.
       Post #: 311
RE: Why you love the OMP Fusion? - 8/11/2008 1:21:55 PM
AFSalmon
Status: offline
Gringo, thanks for the report on the Fusion. You might want to redirect the exhuast of the engine so it does not spray so much oil on the wing/fuselage joint. Also make sure the root rib is fuel proofed so if you do get some oil in there you can wipe it off easily. Hope this helps.
       Post #: 312
RE: Why you love the OMP Fusion? - 8/11/2008 2:30:27 PM
Gringo Flyer
Status: offline
The exhaust from the muffler is shooting down below the wing. I think the residue I am seeing is from the carb. Its a lot of oil.
Maybe the residue is coming from somewhere else.
       Post #: 313
RE: Why you love the OMP Fusion? - 8/11/2008 2:49:34 PM
sodbuster 1
Status: online
Gringo, this might sound like a silly question but............
do you have the cranckase breather nipple plumbed?
       Post #: 314
RE: Why you love the OMP Fusion? - 8/11/2008 3:22:11 PM
daveopam
Status: offline
I was wondering the same thing. I can't see a line in the pictures but they are small. On mine I put a small loop on the front hatch. This is the hatch where the throttle servo plugs in. Then I just ran the blow by line through the loop.
David
       Post #: 315
RE: Why you love the OMP Fusion? - 8/11/2008 4:10:53 PM
Gringo Flyer
Status: offline
This my first
