Spacey
Joined: 1/27/2004 From: Pretoria, SOUTH AFRICA Status: offline
Little hard to describe the little booboo yes, not sure if pictures would show it clearly either but yeh reason I aint complaining is cause I'm not too sure it's not something I mucked up either? When I ligned the in place pre build hardwood engine mounting rails up with the ply sheeting doublers's cut out the fus sheeting was actually overlapping the bottom I-beam a little more than halfway. Later judging from the pictures in the manual the sheeting looks like it comes to a stop butting into the bottom I-beam? But this wouldn't work as the I-beam is not wide enough anyways. Either way, I aligned the engine mounting area properly and tried my best to get the wing tube and alignment holes aligned vertically as well as the rear of the sheetings so the stab and such would be close enough then just glued it all together. My I-beam was a teensy bit wider than the foam core but barely a fart so it lifts the front ply doubler slightly from the foam in the motor mounting area...this is really barely noticeable but maybe a good idea to pour some thinned wood glue in there or something just to beef it up for the shakey 1.25? The foam core is slightly bigger than the sheeting around the rear of the cockpit and top of the fuselage also, but this I'll just trim away, not much (Maybe 2mm). At the back of the fus though the sheeting is about 15mm too long, easy to trim also. I'll get some pictures asap.
