Spacey
Joined: 1/27/2004 From: Pretoria, SOUTH AFRICA Status: offline
Hi guys! Been a while since I've started a thread on RCU but my time has been limited in the past due to other commitments and finally I have the most of that off my back. Now I can contemplate a few moves in the fixed wing arena again and apart from the number of gliders I wanna spend some quality time on I also want to consider getting another profile. The last 3D model I bought was my 63" Phoenix Yak-54 but I'm considering just giving that away since the sun destroyed its canopy and I haven't had much luck getting it replaced, other problem was the Saito 1.25 I have on it is barely enough power to 3D the model at the 4500' I fly at with the model weighing 3,4kg odd dry. So now I've always had a liking in the Fusion but only now I can actually consider getting one myself. My concerns though are simply will the Saito 1.25 be enough for a kit built Fusion at my altitude to really make the model shine? I'm also curious if the Fusion (With some time spent trimming and and) will be able to fly advanced and expert pattern competitively? I have no intentions to take on a proper 2X2 but I would like to start competing in pattern just as an optional extra fun pass time? I like to think that have the stick skills to be competitive with pattern but I have no intentions to actually get caught up in the F3A thing as that's just simply too expensive. For the most part, if I get one, my Fusion will be used to hone my precision flying skills and to at the same time 3D. Also I want to use it as a show plane if you will for fixed wing demos at fly-ins etc. And then very importantly it will serve as my Freestyle competition plane also. You guys reckon this bird will do the trick? I really wanna stick with a profile for now if I buy something new, the fatties are just too darn fragile. Cheers, Spacey
