thestratcat
IL, USA Status: offline
quote:
ORIGINAL: HelisRule That said, for those of you using the GP Equinox balancer, is it my understanding that the LiPo will plug into the Equinox and the Equinox will plug into the charger? If so, looking at the pictures, it looks like the Equinox has banana plugs that I assume plug into the charger. What type of input 'jack' or connector do I need to go from the TP1320 to the balancer, or will that plug in with its stock balancing connector? But then how does the battery cionnect to the...and will I have any need for a banana to ultra deans adapter? What? How? No hair left...going to burn down my house...help! Sorry, could you please advise as to how all these things are going to connect? Thanks. the way it was explained to me, and I believe it says on the website also.. they equinox can be use with or without a charger, the way it was explained to me, you can plug the balancer into your pack as a stand alone, it'll balance the cells out and then you charge via the deans connection. Or, if you want, you can use it inline with the charger.
_____________________________
"If guns cause crime, all of mine are defective" ~ Ted Nugent.
