Help Honey Bee FP Stronger parts
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> Help Honey Bee FP Stronger parts
Page: [1]
Login
Help Honey Bee FP Stronger parts - 8/13/2007 10:52:30 PM
technical35
Status: offline
I have a Honey Bee FP and the parts keep breaking. The paddle control frame conection balls keep breaking off. I havent been able to take off without them breaking off. Are there any Honey Bee FP aluminum upgrades that I can put on it? This has been so frustrating and I havent even flown it more than 3 seconds before it lifts off and banks left and forward at Mach 6.
       Post #: 1
RE: Help Honey Bee FP Stronger parts - 8/14/2007 2:10:02 AM
blade_killer
Status: offline
no, there are no cnc parts for the HBFP. We all break the paddle control frame, not every time we fly but in almost any hard-ish crash they break. You can try gluing the balls back on with CA then wrapping the break with thread then soaking the thread in CA, it works good but wont survive another crash.
It sounds like your completely out of trim or out of balance if it's shooting off in some direction. The FP and really any micro with skid to the left when you lift off, the trick is giving it a burst of throttle to get it up over 12" off the ground and then slowly applying speed to lift it up higher, you will however have to compensate a little for the ground effect as you lift off.
Make sure your FP is balanced and that your swashplate is level.
_____________________________
Scott
(in reply to technical35)
       Post #: 2
RE: Help Honey Bee FP Stronger parts - 8/14/2007 2:19:43 AM
KCinNC
Status: offline
big difference when you get it off the ground a little quicker...
(in reply to blade_killer)
       Post #: 3
RE: Help Honey Bee FP Stronger parts - 8/14/2007 7:00:08 AM
mrasmm
Status: offline
yeah, the only alum part I have seen for this heli is on ebay, and it's the rotor head core.
It does sound like you definately have a trim problem. What I would do is with the training gear on get the heli so it is a bit light on the skids and it doesn't lift off, make sure to do this in no wind, and trim the heli so it doesn't move around too much. It will have a tendancy to go to the left, so don't trim all of that out, or when you get out of GE or about 2 to 3 feet in the air, then your heli will really want to go to the right.
It sounds like you could use some setup though. Also before you do that to get a rough ballpark, level the swash plate, so perpendicular to the mainshaft, in all directions
I don't always check every thread I respond to, so feel free to PM me
(in reply to KCinNC)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU3
