exceed rc ultra
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Exceed RC Support - Nitro Cars >> exceed rc ultra
Page: [1]
Login
exceed rc ultra - 8/14/2007 3:17:52 AM
nitrolambo88
Status: offline
whats up everybody...i just purchased an exceed 2 speed on road nitro car from raiden tech...i was just curious...is it a good car and what should i do to get started...we have the fuel and everything needed to get goin...but pointers are always good when you are new at this hobby and dont know what you are doin
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: exceed rc ultra - 8/14/2007 4:18:33 AM
AllAboutFunHobbies
Status: offline
Looks good, just an FYI, the parts for that car are the same as the Redcat Lightning, matter of fact that is the exact same as the Redcat lightning.
First thing I would do is check and make sure that they are using the new steel clutch bell, if the clutch bell is aluminum I would replace it with the new steel one or you run a major risk of stripping your gears first run out. The aluminum clutchbell warps under heat. Redcat is having there cars built with the Steel clutch bell, but I can't speak for the rest of the companies having Hi speed toys build there cars.
The car is super fast man. Your goign to love it, they drift great.
_____________________________
Dealer for...Redcat Racing, Traxxas, Team Associated, Cen, Racers Edge, RD Logic, Bodies by Blue, HPI, Himoto USA.....etc
(in reply to nitrolambo88)
       Post #: 2
RE: exceed rc ultra - 8/14/2007 4:27:17 AM
nitrolambo88
Status: offline
thanks man...i appreciate it...ive been lookin around and it seems like you know your stuff...but where would i go to get a steel clutchbell and how easy is it to replace?
(in reply to AllAboutFunHobbies)
       Post #: 3
RE: exceed rc ultra - 8/14/2007 4:46:18 AM
nitro61
Status: offline
you just go to his website http://allaboutfunhobbies.com
       Post #: 4
RE: exceed rc ultra - 8/14/2007 12:54:32 PM
keystone82
Status: offline
does it matter how many teeth it has cuz mine on my truck is a 16t but they dont show one?
(in reply to nitro61)
       Post #: 5
RE: exceed rc ultra - 8/14/2007 1:12:28 PM
AllAboutFunHobbies
Status: offline
Ya kind of, if you go up in teeth then you gain top speed and loose take off speed, if you go down in teeth you gain take off speed and loose top speed. You could go up one tooth to like a 17 tooth and gain alittle top speed and not loose to much take off speed or you could go down one tooth and gain some take off speed and loose alittle top speed Or you can go with the stocker and it will stay the way it is.
Stock Clutch bell:
http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=29
< Message edited by AllAboutFunHobbies -- 8/14/2007 1:14:09 PM >
(in reply to keystone82)
       Post #: 6
RE: exceed rc ultra - 8/14/2007 4:15:03 PM
{GBI}Harryball
Status: offline
quote:
ORIGINAL: AllAboutFunHobbies
Stock Clutch bell:
I run that clutch bell in my volcano, and it rips.
Sponsered by: ALL ABOUT FUN HOBBIES /ALL ABOUT FUN HOBBIES PRODUCT REVIEWER
       Post #: 7
RE: exceed rc ultra - 8/15/2007 3:10:35 AM
nitrolambo88
Status: offline
AAFH...thanks for all the info...i ran my car for the first time today and its sick...i checked the clutch bell that you were talkin about and found out that it is in fact steel so were good on that situation...the only other question i have is when we get it started and we go to take off there is a delay in the acceleration and it wasnt like that when we first started...could it be because the batteries in the car are low...im goin back out tomorrow and i need to know if need new batteries or if i just need to do some tuning...thanks for all replies givin
       Post #: 8
RE: exceed rc ultra - 8/15/2007 12:35:39 PM
{GBI}Harryball
Status: offline
Sounds like a bog, give the HSN a 1/16 turn in, that will lean it out a bit. Should help with the bog issue.
       Post #: 9
RE: exceed rc ultra - 8/15/2007 4:13:27 PM
nitrolambo88
Status: offline
thanks for the info...im gonna head up to a hobby shop here in about an hour and pick some stuff up then ill try workin with the needle and let ya know how it worked out...thanks again
(in reply to {GBI}Harryball)
       Post #: 10
RE: exceed rc ultra - 8/15/2007 10:12:05 PM
nitrolambo88
Status: offline
ive got one more quick question...my engine says its a .16 CXP engine...what exactly does the .16 mean and how much power is it pushing out?
       Post #: 11
RE: exceed rc ultra - 8/15/2007 11:50:31 PM
AllAboutFunHobbies
Status: offline
If it bogs when you hit the thorttle on take off, you may also need to give the LSN a 1/16th adjustment in. The LSN controls your take off fuel flow. Your head temps should be between 200-230 degrees F. Your deffinatly good on the clutch bell then if it's steel.
.16 is the Cubic Inches so the engine is about a 2.5 Cubic Centimeter engine, they don't really rate the nitro engine as far as power wise, but it probablly has somewhere in the neighborhood of 3/4 horse give or take.
.18ci is 3.0cc and so on
So when you see Traxxas advertising a 3.0 engine they really mean a .18 or if a company is advertising a 3.3 it would be .21.
Alot of companies are starting to use the Cubic Centimeter instead of Cubic Inches because it makes it look like the engine is bigger than the competitors and they bank on the fact that most people don't know that a .18 and a 3.0 are the same size motor.
On your car you can upgrade to about a .18 small block. There are alot of options in the .18 size, like O.S. has the .18 CVRs and SH has a .18, infinity .18, Novarosi .18 . You can also change your clutch bell gears to get different types of preformance. If you bring your gear up higher you get a crap load of top end speed, but sacrafise low end take off, if you bring the gears down you get a crazy amount of low end speed and sacrafice top speed. SO basically if your car does say 45 now and you put taller gears on the clutch bell it could do say 50 to 55 easy. If it does 45 now and you put on lower gears it will do maybe 35 to 40 but WAAAYYYY faster.
       Post #: 12
RE: exceed rc ultra - 8/16/2007 1:30:08 AM
nitrolambo88
Status: offline
thanks for the info about the engine...i ran it today and everything was perfect and i almost have it broken in...1 or 2 more tanks through it and ill be done with that process...but i ran into a couple problems when i was running through my last tank...when i would slow the car down to a coast i would hear a slight clicking noise and i dont know what it is...and also the first 2 tanks the car ran like a champ and on the third tank it wasnt shifting out of first gear...could it be because the engine was to hott or what...if thats not the problem then what could it be...i need the answers to both questions asap...im runnin it again tomorrow
       Post #: 13
RE: exceed rc ultra - 8/16/2007 12:59:57 PM
{GBI}Harryball
Status: offline
Check your PM, and after you have it broken in. Check this link out. It will help with the second gear adjustments.
http://www.rcuniverse.com/forum/m_4207842/anchors_4207842/mpage_1/key_2nd%252Cgear%252Cshift/anchor/tm.htm#4207842
       Post #: 14
RE: exceed rc ultra - 10/25/2007 3:56:03 AM
Erik B
Status: offline
do any of u guys know if the Reckward Tuning Speed 3 Automatic Racing Clutch System (http://www.amainhobbies.com/product_info.php/cPath/1_23_78/products_id/4670)
would work with the stock engine gear on the exceed rc car?
       Post #: 15
RE: exceed rc ultra - 10/25/2007 3:12:06 PM
{GBI}Harryball
Status: offline
quote:
ORIGINAL: Erik B
