Shrink Wrap Covering
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> Shrink Wrap Covering Page: [1]
Login
Shrink Wrap Covering - 8/14/2007 5:40:41 AM
gullwingcorsair
Status: offline
Hey Folks,
Has anyone tried shrink wrap covering? The type you use on a Marine Boats.
I know you can get 3,4,5,7mils in thickness, and that stuff is damn hard to puncture.
I was thinking if you Spray Glued the foam, then add the wrap. Seemed it. Then Shrunk It. It "could" be a strong covering.
Had to put emphasis on the could!
What do you think?
STu
_____________________________
What did I just say?
       Post #: 1
RE: Shrink Wrap Covering - 8/14/2007 1:57:59 PM
Montague
Status: offline
It might be possible, but doesn't it use a fairly high heat to shrink? Too much heat will melt the foam under it. Give it a try and let us know.
Another issue may be it's failure mode. One of the advanages of tape is that the seams provide a natural "ripstop" effect. Tears stop at the doubled seams which prevents the entire wing from failing all at once. But from what I recall from using that kind of stuff, it is rather hard to tear.
Kirk Montague Adams
RCCA 560
(in reply to gullwingcorsair)
       Post #: 2
RE: Shrink Wrap Covering - 9/24/2007 3:52:16 PM
boiler1
Status: offline
Since tape is about 0.5 mill thickness, I would guess that the shrink wrap would be tough as nails but very heavy.
(in reply to Montague)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU3
