Andprise
Thanks BladEagel, In fact, this is my first gasoline Edge, I have had a foamy edge, they also have a characteristic of easily snap when you try to recover during an error in preforming 3D, eventually, how I deal with it is to apply a small fin on the wing tip like QQ currently imply on his new 86" Yak, but it has lost the ability of preforming extreme 3D, it cannot even snap when u wanted to either, it is a very big trade off. Anyway, in this composite airplane, there is not much weight I could have reduced from it, and the wing loading in comparison to other 50cc like my EF Yak 54, this x'treme edge is a bit heavy in its size. BTW, could you share the radio setting and the CG setting on you plane, and I am very much interest if you could share your experience in setting this edge to do waterfall either. At the beginning I was setting the CG at 123mm from the LE of the wing with about 220g lead added behind the nose ring and with all the batteries moving very forward behind the firewall, it is very stable but hovering is very difficult and the harrier roll is also difficult too due to the heavliy nose. With the CG set as per manual, it preform very like a good F3A plane. After serval flights, I reduced around 60g of lead from the nose, the CG on mine now is about 1/4 inches in front of the aileron hinge line measure at the wing tip, after this changes, hovering is a bit easy with not much nose drop correction, but I will continuous to reduce the lead, as the CG doesn't seem right when preform harrier roll, the nose seems to swing during this manuver. The setting on my Edge: the Aileron 30degree with expo 40%, elevator 40 degree with expo 50%, and rudder 45degree with expo 50%, and forgot to mentioned, 2 of my hinges out of 4 at the rudder was broken after around 12 aggressive 3D flights, I was lucking did not crash it, it went into snap roll after a normal stall turn, I could manage to recover it almost at round 20 ft. I landed and check the plane all over, then I found those hinges were broken, I was worried about the size of those hinges during assembly, now I realised that it was not the size (only 3mm) to handle aggressive 3D, I changed it to a 5mm size hinge and went to fly on last Sunday, I tested it after 4 round of aggressive 3D, they stay strong on the position.
