BaldEagel
Joined: 10/12/2005 From: Wychling, Kent, UNITED KINGDOM Status: offline
The nylon bolt that is in the fus and goes into the keyhole on the cowl is 4mm, the same size as the SebArt wing retaining bolts for the Angal and 30size Katana, if you are talking about the front bolt then that is 3mm. If you need instructions for that step go to the Graupner web site and look for the downloadable instructions for their electric version, they recommend epoxying the tail tube into one side, I don't like this because if you bend it you need a new elevator half as well, so I attached both sides with a bolt and T nut epoxied inside the tube, the hole for the bolt is 110mm out from the root edge of the tailplane, there is a plywood reinforcing plate there, the surface of the tailplane can be recessed to take the bolt head, taped over for flight. If you are missing so much from BVM I would suggest you send it back, also check to see if the rear fus former is in place as detailed earlier in this thread. Mike
< Message edited by BaldEagel -- 6/19/2008 10:49:41 AM >
______________ |
