AirRayInc
Joined: 12/30/2001 From: San Pedro, CA, USA Status: offline
When I picked up the plane, and put the first dozen or so flights on the plane, I found the plane very very nose heavy. I found myself making high speed passes to set up for a landing, before I got the guts to start moving the cg more aft. ahhhhh, so nice. Unfortunately, I have the plane all broken down, as I get up the funds to upgrade the booms to the fiber glassed ones. I am going to assume that the plane I own was set up nose heavy, more so than the plans say. Flight performance was there was not alot of change when flying through gentle climbs and dives, but heavy pitch changes required alot of stick inputs prior to moving the cg back. If some one posts what is on the planes, I can do a pretty good guess ti mate as to where I think my plane is at. My suggestion would be follow the leads above, move the cg forward, watch your approach pace, as in keep it fast. The plane will bleed alot of speed with gear down, props throttled back and flaps once you get over the numbers. Later start moving it aft VERY SLOWLY, and you will find a nice balance, and be very surprised at how slow you can bring the plane in and be able to flare as well. Best of Luck, Ray
_____________________________
My Blog http://www.rcgroups.com/forums/member.php?u=9311 http://airrayinc.com
