what servos
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> what servos
Page: [1]
Login
what servos - 8/15/2007 2:08:26 AM
rthalls
Status: offline
I just crashed my dynaflite suer decathlon on the first flight ------- was useing two Hitec HS-475HB sevros on the elevator and one striped ---[ no more plane ] ........I have built two other gas planes but not flown them yet with the same type servos [ these our G-38 engiines ] what should I use , can't afford the expencive servos . are the resin gears able to be replaced with nylon gears ??
any help appreciaten , hate to give up on gas engines so soon . thanks bob
       Post #: 1
RE: what servos - 8/15/2007 3:09:17 AM
Richard D Bahmann aka/Wrongway
Status: offline
HS-475HB = $16.99 each
Hitec HS-645MG High-Torque 2BB Metal Gear Servo = $35.99 each
or about $20 more per servo.
The trick with the Gasoline powered engines is to stay away from plastic gears and stay with metal gear servos of ample ability.
So you might spend an extra $100 more on servos but ask if it will cost more than 100 to repair/replace your broken plane.
Hope this helps.
Richard
_____________________________
To go where no man has gone before...without government permission. In 1938 Wrong Way Corrigan becomes an American Hero.
(in reply to rthalls)
       Post #: 2
RE: what servos - 8/15/2007 3:35:36 PM
DadsToysBG
Status: online
Ten dollar servo's $300 airplane. You save $40 on the tail and loose $300. I think you get the point. JR sport 126 34.99. Dennis
Dads Toys. I fly what I sell
CD Vette City Big Bird
       Post #: 3
RE: what servos - 8/16/2007 12:16:02 AM
Bass1
Status: offline
I'm pretty sure that karbonite gears and vibrating "gas engines" are a serious no-no . The 645mg servos are the way to go if you're on a tight budget. I would pull those "karbonite" geared servos out of your other gas planes YESTERDAY and install them in your glow or electric planes preferably under 12lbs. for safety. I have a set in a .46 size profile and they are fine for that application.
       Post #: 4
RE: what servos - 8/16/2007 6:15:26 AM
nitro wing
Status: offline
quote:
ORIGINAL: Bass1
Definately agree with the above,no nylon or karbo gears for your plane,or the G38 ones..
The 645's are old school,reliable,tough and affordable.I have heard guys with G 62's running them.You can put them on 6 volt for extra power without any issues.They tend to get some play in them after a bit,but for sport use its not an issue.
(in reply to Bass1)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU3
