AFPD can't find transmitter
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> AFPD can't find transmitter Page: [1] 2 3   next >   >>
Login
AFPD can't find transmitter - 8/15/2007 2:55:54 AM
fly4fun
Status: offline
I just installed AFPD on my new computer and it says it has located the usb, but cannot find the transmitter. I did install the update patch. My new computer is running windows vista, i don't know if this makes any difference. But i haven't used the sim in a long time, and don't have another computer to try it on. I'm using the same transmitter that it worked with before. Is this a problem with the usb cord? I've tried two different transmitters.
       Post #: 1
RE: AFPD can't find transmitter - 8/15/2007 8:29:13 AM
rajul
Status: offline
fly4fun, which radio are you using? Which patch did you install? Did you install any addons?
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to fly4fun)
       Post #: 2
RE: AFPD can't find transmitter - 8/16/2007 3:11:07 AM
FrankFuss
Status: offline
I had the same problem until I switched the transmitter to PPM mode.
       Post #: 3
RE: AFPD can't find transmitter - 8/16/2007 4:21:10 AM
fly4fun
Status: offline
I'm using a JR XF631 (which worked before) and I tried a futaba skysport. I don't think it's the radio because it worked with AFPD before. I installed the latest patch on the website.
(in reply to FrankFuss)
       Post #: 4
RE: AFPD can't find transmitter - 8/16/2007 8:18:41 AM
rajul
Status: offline
fly4fun, are you using a JR adapter between your JR radio and the usb interface cable? Also, please set your radio to PPM mode
Mike Marks
RCU Moderator
       Post #: 5
RE: AFPD can't find transmitter - 8/18/2007 7:49:10 PM
tbald2u
Status: offline
Just bought AFPD and have same problem. Program cannot find TX (JR XP6102). Am using JR micro connector. TX set to clear plane and on PPM. Get msg that I need open GL version 2.0 or better. Don't have Open GL as I have Dell Dim. E310. Has internal graphics card. Am I stumped.
       Post #: 6
RE: AFPD can't find transmitter - 8/20/2007 8:32:07 AM
rajul
Status: offline
tbald, you need a GL-compatible 3D graphics card such as the ones listed here http://www.aerofly.com/www/requirements.html The integrated graphics card will not work. Please also take a look at the other system requirements
Mike Marks
RCU Moderator
(in reply to tbald2u)
       Post #: 7
RE: AFPD can't find transmitter - 11/29/2007 2:27:00 AM
driftair
Status: offline
I am having the same problem. I am running WinXPH and also running ReflexXTR, Realflight G4, and Aeroflypro Deluxe.
When I connect the dongle it is recognized, when I connect my T9CHP it is not recognized.
I have tried this before starting AFPD and after starting AFPD.
Once it worked for a min or two and then stopped working again!
We attract what we think, feel, and express, therefore, a good focus is; clarity, love, peace, creativity, wealth and health
(in reply to rajul)
       Post #: 8
RE: AFPD can't find transmitter - 11/29/2007 9:57:55 AM
rajul
Status: offline
Sounds like your adapter may be faulty. Where did you get your adapter from? What is the error message that you see?
Mike Marks
RCU Moderator
(in reply to driftair)
       Post #: 9
RE: AFPD can't find transmitter - 11/29/2007 4:46:39 PM
driftair
Status: offline
Thank you for trying.
My adapter is working fine, always has. I installed DirectX tried to install the most recent but it does not read that way. Then I reinstalled AFPD and applied all updates in consecutive order from the first to the most recent.
I connected the dongle and the Xmitter and they were recognized and functional. I then restarted the system and AFPD without the dongle and Xmitter connected, while the program was booting up I connected the dongle and Xmitter, the dongle was recognized but the xmitter was not. I then shut down the program, left the dongle and xmitter connected, waited a min or two and restarted the program, now everything is recognized and working.
Guess in addition to reinstalling and applying the updates in order from first to most recent the dongle and xmitter had best be connected before starting AeroFlyPro Deluxe.
It's working. :-}
(in reply to rajul)
       Post #: 10
RE: AFPD can't find transmitter - 11/29/2007 10:45:47 PM
rajul
Status: offline
OK sounds good.
Mike Marks
RCU Moderator
       Post #: 11
RE: AFPD can't find transmitter - 12/1/2007 2:43:26 AM
driftair
Status: offline
Now what I would really like is to have AeroFlyPro Deluxe recognize my RealFlight G4 Interlink Controller.
Right now it does not.
I have all the updates and of course the dongle is plugged into a USB port, but AeroFlyPro Deluxe still does not recognize the Interlink Controller.
Does anyone have a solution that will enable the use of the RealFlight G4 Interlink Controller to practice flying with AeroFlyPro Deluxe?
Thank you for your help.
(in reply to rajul)
       Post #: 12
RE: AFPD can't find transmitter - 12/3/2007 2:46:22 AM
rajul
Status: offline
Driftair, you'll have to configure the controller as a "joystick" in the controls menu
Mike Marks
RCU Moderator
       Post #: 13
RE: AFPD can't find transmitter - 12/3/2007 7:00:10 PM
driftair
Status: offline
Hi Rajul,
The last time I tried, (which was before I read your last messge) I could not find any indication that AerolfyPro Deluxe recognized the controller in anyway at all.
Are you suggesting that I use windows 'Game Controllers' to set up the controller as a joystick? OR are do you simply mean to choose a joystick that indicates 2 sticks, 3 switches, one knob, and ? buttons?
I will of course try that to see if I get any response that indicates the program can see the controller.
Thank you.
OK
From within Aeroflypro Deluxe, I clicked on 'Controls' and 'Aircraft Control Settings' appeared.
I clicked on 'New' first, with Transmitter highlighted,
The configuration window that opened indicated "NEW"
I moved the control arms and switches around and nothing on screen responded.
I then clicked the 'Advanced' button and moved control arms and switches, still nothing responding.
I then clicked on a radio channel button, and in the 'Select channel' window,
moved control arms and switches trying to see if anything showed up, nothing responded.
I tried the same under joystick, and every choice except "USB Interface/GameCommander" was grayed out and not accessible to choose.
Nothing I tried indicated that the "RFG4 Interlink Controller was recognized.
P.S. I have all of the AFPD updates installed.
< Message edited by driftair -- 12/3/2007 7:38:56 PM >
(in reply to rajul)
       Post #: 14
RE: AFPD can't find transmitter - 12/4/2007 7:32:30 AM
rajul
Status: offline
In some cases there could be a usb conflict. Try connecting the interlink to other usb ports. When you plug in your G4 controller and then go to your computer's "control panel" and select game controllers, do you see the G4 controller recognized? How did you connect your interlink to the PC? Did you use the cable that goes through the antenna receptacle, or the cable behind the controller?
Mike Marks
RCU Moderator
       Post #: 15
RE: AFPD can't find transmitter - 12/4/2007 4:04:48 PM
driftair
