HELP! sticks are reversed...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> HELP! sticks are reversed...
Page: [1] 2   next >   >>
Login
HELP! sticks are reversed... - 8/15/2007 2:29:50 PM
thestratcat
Status: offline
I can't figure this one out.. first off the facts...
I'm using a futaba 6exh transmitter, I'm trying to make an Axe CP fly. This is where everythign goes bad for me... I've got the same frequency in the Axe as on the transmitter. Now, we're using the stock reciever for the heli, I've got the motor unplugged and as soon as I get through the transmitter/reciever problem I'll go on. When I started the swap, I looked at the movement in servos and swash from the stock setup and wrote everything down. I set up the transmitter (a guess anyhow) and everything seems to work, here is the exception:
the right stick is supposed to control forward/aft cyclic and the left should control the speed (along with moving the swash down on the main shaft), my problem is these two sticks are reversed! Everything moves fine, as it should, except, the sticks are reveresed.
do I need to go with a futaba reciever? is it something in the transmitter programming? Am I losing my mind????
thanks guys!
_____________________________
"If guns cause crime, all of mine are defective" ~ Ted Nugent.
       Post #: 1
RE: HELP! sticks are reversed... - 8/15/2007 2:32:38 PM
Revo_Rash
Status: offline
flip the switch on the tx for the servo. if it's in normal then switch it to reverse. and vice versa
Def of NITRO: Nothing like the sounds of her screaming and the smell of her sweating...
(in reply to thestratcat)
       Post #: 2
RE: HELP! sticks are reversed... - 8/15/2007 2:59:44 PM
thestratcat
Status: offline
quote:
ORIGINAL: Revo_Rash
no, it's not reverse movement, the sticks are reversed from what they are supposed to be controlling..
for example..
push forward on the throttle, it's moving my swashplate like it would to give forward cyclic...
push forward on the cyclic and it moves the swash up and down like the servo's move it when you give it throttle..
(in reply to Revo_Rash)
       Post #: 3
RE: HELP! sticks are reversed... - 8/15/2007 3:00:51 PM
soop7667
Status: offline
Is the Axe CP an eCCPM heli, or is it mCCPM? If M, you should be able to swap the throttle lead with the elev. lead. - If not I dunno, that would take some thought and I'm not really wanting to think right now.
       Post #: 4
RE: HELP! sticks are reversed... - 8/15/2007 3:03:04 PM
alienteabagger
Status: offline
Yeah... sounds like your in the wrong "MODE"
Radios have two MODES, in each mode the sticks are reversed. Its those crazy pilots on the european continent (especially the French) who fly in the mode that has the throttle on the right stick. Then again don't european helis spin their rotors in the opposite direction too???
Just switch your Radios mode.
Zit: T-Rex450SA Tiny: Thunder Tiger Raptor 50
http://www.rcuniverse.com/forum/m_7591039/tm.htm
       Post #: 5
RE: HELP! sticks are reversed... - 8/15/2007 3:05:15 PM
thestratcat
Status: offline
ok, I can switch the stick modes (it's in 2)...
but if I make changes to this, won't it make changes to all the models?
(in reply to alienteabagger)
       Post #: 6
RE: HELP! sticks are reversed... - 8/15/2007 3:07:38 PM
soop7667
Status: offline
Damn - sounds almost like you have the wrong mode transmitter - where'd you get the TX? Is it mode 1 or mode 2?
(in reply to soop7667)
       Post #: 7
RE: HELP! sticks are reversed... - 8/15/2007 3:08:49 PM
soop7667
Status: offline
Wow - when replies rush in - you can't veen keep up with the postings!
       Post #: 8
RE: HELP! sticks are reversed... - 8/15/2007 3:08:53 PM
[]TEX[]
Status: online
You need to put teh swash mode to 3S if it is not already. I think the default on my 6EXH was 1S, the Axe is 3S.
Secondly, disconnect all the servos and start over.
Pitch and throttle are mixed still have their respective channels 3 and 6. On the front panel of the 6EXH is the list of channels.
It's a simple fix, you just have the channels mixed up. Swap the connectors for channels 2 and 6.
JR Vibe 50 powered by O.S. | 7C FASST | Hatori Perfomance | Curtis Youngblood | Reactor X | CSM RL20 | mCX
       Post #: 9
RE: HELP! sticks are reversed... - 8/15/2007 3:15:54 PM
[]TEX[]
Status: online
quote:
ORIGINAL: thestratcat
Yes, that is the whole point. you want mode 1 for all.
< Message edited by []TEX[] -- 8/15/2007 3:16:40 PM >
       Post #: 10
RE: HELP! sticks are reversed... - 8/15/2007 3:16:37 PM
thestratcat
Status: offline
quote:
ORIGINAL: []TEX[]
ok, the swash is in 3S, I'll give the swap a try..
I am in mode 2 by the way, but I'm afraid that if I switch that to something else, it may effect my other models, that wouldn't be good.
(in reply to []TEX[])
       Post #: 11
RE: HELP! sticks are reversed... - 8/15/2007 3:17:40 PM
thestratcat
Status: offline
quote:
ORIGINAL: []TEX[]
then that will make the sticks wrong for my MX400..
this can't be the answer then!
       Post #: 12
RE: HELP! sticks are reversed... - 8/15/2007 3:18:38 PM
[]TEX[]
Status: online
quote:
ORIGINAL: []TEX[]
What other models do you have on there?
Mode 1 is the correct mode, not mode 2.
For now, don't change the connectors. Try it out first.
       Post #: 13
RE: HELP! sticks are reversed... - 8/15/2007 3:21:11 PM
[]TEX[]
Status: online
Wait a minute, are the sticks correct on the MX400?
       Post #: 14
RE: HELP! sticks are reversed... - 8/15/2007 3:24:19 PM
thestratcat
Status: offline
quote:
ORIGINAL: []TEX[]
the MX in mode 2 flies like a dream! that's what's got me screwed up here..
       Post #: 15
