YAK 54 - 85" with ZDZ Super 80
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> YAK 54 - 85" with ZDZ Super 80
Page: [1]
Login
YAK 54 - 85" with ZDZ Super 80 - 8/15/2007 2:35:19 PM
smek88
Status: offline
Hi Reza,
I'm looking to possibly purchase a YAK 54 - 85" with a ZDZ Super 80 this weekend. My question is: Is this going to be a good set up for the plane. It should be massive power for the plane. I've read the recommended sizes to run in the plane and says 50-80 cc gas. I think the motor weighs in at 4.4 lbs. This sounds like an awsome combination but wanted to make sure there are not going to be any unforeseen problems with this. The plane is already built and owner says it only has 2 flights on it but not by himself. It also has hitec 5955's all the way around. For the money he's asking I can't pass this one up.
Thanks in advance for any input you may be able to provide.
Rob
       Post #: 1
RE: YAK 54 - 85" with ZDZ Super 80 - 8/19/2007 5:40:57 AM
kochj
Status: offline
Actually it say 50-60cc gas....
The 80cc may be to high of a wing loading!...
I would look into the Aero-works quick build Yaks and extra that are made for the 75cc -80 motors....!
Now that would be a awsome setup!....
http://aero-works.net/store/detail.aspx?ID=264
These will fit that engine and from what I have seen have been great planes!...
Justin
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by kochj -- 8/19/2007 5:44:22 AM >
_____________________________
Winning isn''''t everything, it''''s all there is.
(in reply to smek88)
       Post #: 2
RE: YAK 54 - 85" with ZDZ Super 80 - 8/20/2007 2:40:33 PM
BaldEagel
Status: online
The plane will take it, I have a MVVS 58Pro (8.5bhp) in one and its a very good combination, the only problem I envisage with the ZDZ 80 is sufficient ground clearance for the prop that the motor would need, I run a 22x10 three blade, which is just right for the MVVS.
Mike
No matter what anyone says 100% is the maximum you can get.
(in reply to kochj)
       Post #: 3
RE: YAK 54 - 85" with ZDZ Super 80 - 8/20/2007 8:55:27 PM
smek88
Status: offline
Thanks for the input guys! I did go down to Orlando and puchased the plane. Looks really nice. The guy that built it did put taller landing gear to accomadate the 26x10 prop. However, I got it started yesterday and it had a really bad engine vibration. It has a POS zinger 26x10 prop on it that probably isn't balanced (who in thier right mind flies Zingers on giant scale anyway!?!?). I ordered a new TBM today, hopefully thats all thats wrong. It does have massive power though and should be even better once the vibration is gone. I have to rewire the plane for JR, and for some reason he placed the planes radio switch, and choke inside the canapy. So I'll be reworking that as well. Hopefully I can get a test flight on it this weekend.
Thanks again for the input and I'll post more info once I get a little work time and hopefully some fly time on it.
(in reply to BaldEagel)
       Post #: 4
RE: YAK 54 - 85" with ZDZ Super 80 - 9/1/2007 4:05:21 PM
kochj
Status: offline
Ohh, I did'nt know you already had the plane.....
A Dynamically balanced prop will make a big diference in the RPM's and the VIbrations.....
www.downonthedeck.com
has a great video explaining how to balance a prop properly.....
Even if you already know how to; it my give you some pointers....
Good luck
Justin
       Post #: 5
RE: YAK 54 - 85" with ZDZ Super 80 - 9/3/2007 11:11:11 AM
BaldEagel
Status: online
For re-working the canopy try this:
Mike
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 6
RE: YAK 54 - 85" with ZDZ Super 80 - 9/3/2007 10:25:13 PM
gooseF22
Status: offline
Watch it with that much power. That engine will pull a 35% plane pretty well. Im not kidding. It pulls my 33% suky to the moon at 24 pounds.
Should be nothing short of a roman rocket!!
Goose
Team Fromeco
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.781RCU3
