RE: Looking at custom building one
Tower Hobbies
Logged in as Guest
  Printable Version
FG MT Upgraded Alloy Parts 2speed 29cc - RTR
Seller:  kg2mb
Details:   $1,450.00   |  12/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: Looking at custom building one
Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: Looking at custom building one - 8/23/2007 1:30:39 AM
speedygonzales
Status: offline
Hey Stoney yes plz (will be a big help)
right now im sort of biasing it off of TIGS new era (tnks bud! ) and taking some inspiring looks at RICKS tt (simply amazing)
Bigmodman o ya theres going to be lots of over built parts and should all be riding on a hpi baja shocks.
you guys think a 29 cc will do good for moving this beast. if not i will just look for something more.
_____________________________
MIKE... got to enjoy rchobbies. canada.
team addition rc18t with MAMBA! cen matrix hpi baja 5b wild dagger.
(in reply to bigmodman)
       Post #: 51
RE: Looking at custom building one - 8/23/2007 1:47:38 AM
T I G
Status: online
Heres lookin at you Speedy , any time my friend.
OOOOOOOOOH Ricks TT
Heres a few snap shots for everyone to drool over. Its got to be the best and most detailed TT ever built. Photos care of QSL .
< Message edited by T I G -- 8/23/2007 1:48:36 AM >
Lead Follow or Get Out Of The Way
(in reply to speedygonzales)
       Post #: 52
RE: Looking at custom building one - 8/23/2007 1:53:59 AM
Q.S.
Status: offline
Ok speedy. im still looking when i can. Hey you want a good shock do what i did and get a lift support for a hood or trunk and drill a hole in the lower chamber to release the nitrogen. then sand it and fill the hole with J B weld then Build the top & bottom spring retainer and use valve springs from a real Engine. thet dont get any bigger or stronger than that. thats the type of setup that im making for my Beretta. would work Great on a truck two I got there link on my site. www.quarterscaleberetta.com
Quarterscale Pro Street Beretta. (MASTER)
       Post #: 53
RE: Looking at custom building one - 8/23/2007 2:01:40 AM
speedygonzales
Status: offline
thats the one!
so i have about 4 months to get mine together for Monster Jam (if im envited) where it will see endless big jumps for the whole event.
with my current slow start (ERRR) and school starting in a qouple of weeks and my part time job the build is going to need all the time it can get.
i have some wierd ideas but should get this beast rolling.
< Message edited by speedygonzales -- 8/23/2007 2:03:43 AM >
(in reply to T I G)
       Post #: 54
RE: Looking at custom building one - 8/23/2007 2:04:51 AM
speedygonzales
Status: offline
quote:
ORIGINAL: stoneyberk
kool Stoney lmk when you find em
isnt that realy big? any pic?
(in reply to Q.S.)
       Post #: 55
RE: Looking at custom building one - 8/23/2007 2:14:01 AM
Q.S.
Status: offline
Look at my Beretta in my gallery. they have all different sizes mine are 1' body x 3 1/3'' 1/2'' shaft 2 1/2'' total lengt is 6'' mine are the ones listed as 5.78'' $18.50 each.
       Post #: 56
RE: Looking at custom building one - 8/23/2007 2:17:36 AM
Q.S.
Status: offline
Hey tig sorry about cuttin you short on that PM I'll get back to yaa a little later on them other things i diddent reply to.
(in reply to Q.S.)
       Post #: 57
RE: Looking at custom building one - 8/23/2007 2:18:33 AM
speedygonzales
Status: offline
wow those do look good!
going to need to see if theres anything suitable for the rear.
how is it when you push it down? maybe also need a shock with no spring just for dampening?
TIG i will draw that pic now, just rememberd
< Message edited by speedygonzales -- 8/23/2007 2:19:22 AM >
(in reply to Q.S.)
       Post #: 58
RE: Looking at custom building one - 8/23/2007 2:31:42 AM
Q.S.
Status: offline
They push down easy after you release the nitrogen. you will defently need a spring there isint much force needed at all to compress it. im going with BB chevy valve springs for the Beretta. but there are also spring that would work at most home improvement stores like they use on spring Garage doors. and they have them in different strenghs as well. I think they would work Great on your truck exspecialy if you are going to be going off road with it. jumps and all.
       Post #: 59
RE: Looking at custom building one - 8/23/2007 3:13:28 AM
Q.S.
Status: offline
Hey speedy if you do go with that shock setup when you go to release the nitrogen make a wood jig to put it in and screw it down through the eye holes and screw down a piece of wood on both sides a little taller than the lift support. then make a board for the top and drill a few holes down the center of it and line up one of the holes with the lower chamber on the lift support then screw that board down then use a punch to make the hole. there is alot of preasure in them things. i just sat my jig setup on the ground it wont move when you pop it. then drill the hole a little bigger so the epoxy will adhere good to it. I soaked them in hot soapy water for a few hours then comprssed up and down quite a few times then did the same in fresh hot water then let set to dry for a few days then filled the hole.
(in reply to Q.S.)
       Post #: 60
RE: Looking at custom building one - 8/23/2007 3:25:05 AM
Q.S.
Status: offline
If you cant fig out how to make that jig let be know and I'll post a few pics of the one i made and you can go from that then.
(in reply to Q.S.)
       Post #: 61
RE: Looking at custom building one - 8/23/2007 4:25:34 AM
bigmodman
Status: offline
oh hey stoney i will have to do that soon also.it will be for my rock crawler im making.if you dont mind could you post up some pics of the jig so i can make mine.
when you arent in the mud you arent having fun!!!♠birdy♠customs♠
(in reply to Q.S.)
       Post #: 62
RE: Looking at custom building one - 8/23/2007 4:51:58 AM
speedygonzales
Status: offline
i was just going to say if i would need one lol.
i understand what your saying, a pic wont hurt just to make sure.
you going to do any others soon? how did you get the springs in them????
the shock has more of a springy feeling right?
< Message edited by speedygonzales -- 8/23/2007 4:52:35 AM >
       Post #: 63
RE: Looking at custom building one - 8/23/2007 4:59:08 AM
Q.S.
Status: offline
Hey speedy & bigbodman give me a minute im getting ready to upload some pics of that jig setup. speedy the springs go on the outside of the shock bud. give me a few guys and you will see.
       Post #: 64
RE: Looking at custom building one - 8/23/2007 5:03:40 AM
Q.S.
Status: offline
here yaa go. I might need to upload these on a couple pages not sure yet.
Click to see fullsize image.
Click for fullsize
(in reply to Q.S.)
