Bax
IL, USA Status: offline
Here's the reply we sent in an email to reply. He did mention in his email to us that there were NO air bubbles in the line. There are several things to check. You don't mention which propeller you are using. Typically, a too-large propeller will tend to make the engine run too hot. We'd suggest a 14x6 or 14x8 prop. If the engine tends to run too lean all of the time, you may have to use larger fuel line. Too many modelers use "standard" fuel line, but that's starting to get a bit small for the .91 FX. You'll also need to use larger-diameter tubing in your fuel tank and drill out the clunk. Make sure the fuel tank is well-insulated against the engine's vibrations. Air can easily be agitated into the fuel when the model's in the air, and this leans the mixture. Make sure the muffler you're using is not too restrictive. This is also a sitnificant source of overheating. If the engine's cowled, you must make sure that air entering the cowl actually passes through the fins of the engine. If you can see the air outlet when you look into the air inlet, chances are that the air is following that path and not passing through the engine's cooling fins. Finally, if the engine will run all day on the test stand and not in the model, then the problem is a result of the airframe/engine/mount/fuel system combination, and all avenues should be checked.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America 3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA Service Phone: 217 398-0007 Email: hobbyservices@hobbico.com
