Dos Little Stiks
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Vintage & Antique RC >> Dos Little Stiks Page: [1] 2 3   next >   >>
Login
Dos Little Stiks - 8/16/2007 5:19:21 AM
wildtang
Status: offline
Hello RC world, im new at this. Im Jrbmoto's girlfriend, I had a great time building the Andrews A-Ray kit from Lazer Works and i am ready to start a new project. We have decided to build a pair of Little Stiks together. Eddie at Lazer works fixed us up with a pair of beautifull lazer cut kits and we're about to get started. I would love to see some pics of your start to finish projects...thanx..BRING IT ON!!!!
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Dos Little Stiks - 8/16/2007 5:36:05 AM
jrbmoto
Status: online
This is going to be really fun! Construction will begin saturday morning. I still need to make a Kinkos run to copy the plans and we're ready to start building!
-Johnny-
(in reply to wildtang)
       Post #: 2
RE: Dos Little Stiks - 8/16/2007 4:34:24 PM
aerowoof
Status: offline
are these the nidwest version das little stick?if so how do I get one,30 years ago had one with a st.40,unlimmited vertical performance and this was with radio equipment that weight about 16 oz for the flight pack.
(in reply to jrbmoto)
       Post #: 3
RE: Dos Little Stiks - 8/16/2007 6:40:31 PM
grotto2
Status: offline
I had almost the exact same thing back then.
It was a popular combination after the MAN cover shot with Telford & Violett doing a hand launch.
_____________________________
I finally got a tattoo. It reads, "Born too loose."
(in reply to aerowoof)
       Post #: 4
RE: Dos Little Stiks - 8/17/2007 12:07:20 AM
jrbmoto
Status: online
Yes these are laser cut kits of the good ol' Midwest Little Stik. They are "short kits" that include everything that needs to be cut to a certian shape such as wing ribs, fuselage sides and formers, and tail feathers. Whats missing are the spars, sheeting and hardware. You can still get plans from a couple sources such as AMA or RCM. I aquired my plans from a friend. Lazer works used to supply some plans as a favor to their customers but I belive that they have stoped this service, although it doesn't hurt to ask!! They have a very long list of kits on their website from several sources. Go to www.lazer-works.com and click on "Airplane Stuff" By the way the Little Stik costs $37.43 and even included the scalloped ailerons and elevator! Not sure what engines we're going to use on these babys but I'm thinking about maybe OS LA.40's Any suggestions??
-Johnny-
       Post #: 5
RE: Dos Little Stiks - 8/19/2007 2:34:22 PM
RFJ
Status: offline
Don't remember that MAN cover but these two shots are from RCM January 1969 and show Bud Anders and Larry Leonard.
Liddle Stik weighed 3llbs and was powered by a K&B 40 turning a 10X4 prop at 16K.
Ray
Click for fullsize
Click for fullsize
       Post #: 6
RE: Dos Little Stiks - 8/19/2007 9:09:54 PM
grotto2
Status: offline
My bad.
Thanks, RFJ. These are in fact the cover photos I remember.
(in reply to RFJ)
       Post #: 7
RE: Dos Little Stiks - 8/23/2007 2:37:49 AM
jrbmoto
Status: online
We did get some work done this weekend. One wing is framed up and #2 is on the bench. Its nice to build a whole wing in one piece, I've never done this before! I was lucky to have some 48" 1/6th balsa sheet stock on hand for the leading and trailing edge sheeting but I did have to buy the 1/4" sq and the 1/8"sq spar material My LHS had both in 48" Ed's Covina Hobby Rocks!! Some slight mods, we eliminated a few ribs and added some sheer webbing for strength. I'm sure there is less wood in this structure than stock yet it is very ridged. As for the kit, things are going very smoothly! I went ahead and seperated all the parts from the sheets and am very impressed with the wood quality. Nice straight grain, lightweight stuff! And the the laser cutting is outstanding as always. I had to laugh at the "extra" sheet that Eddie thru in (obviously a set up piece) that had a big hole burnt through it.....I guess the laser was on volume 11!!
Click for fullsize
(in reply to grotto2)
       Post #: 8
RE: Dos Little Stiks - 8/23/2007 5:33:31 AM
OzMo
Status: offline
quote:
ORIGINAL: RFJ
Ray
LOOKS LIKE THE BIRTH OF 3D
Yes dear, I did glue my hand to the airplane to keep from dropping it.
(in reply to RFJ)
       Post #: 9
RE: Dos Little Stiks - 8/23/2007 9:42:54 PM
grotto2
Status: offline
Say, what ever happened to Larry Leonard?
He was big in pattern & racing in the early '70's.
(in reply to OzMo)
       Post #: 10
RE: Dos Little Stiks - 8/26/2007 11:57:36 PM
jrbmoto
Status: online
We made some progress this weekend. Wildtang and I worked side by side finishing up the framing of wing #2 and added the tips to wing #1. We also started on the fuselages. Construction couldn't be more simple, I can see why this was such a popular kit "back in the day" and I'm sure the Lazer-Works kit is much better than the old "die crunched" Midwest kit! I decided to go with a rubber band on wing just for nostalgia but I did want to mention that this kit does provide parts for a cool bolt on wing set up that is an easy mod. I will be using dual aileron servos so that I can eliminate the stock bellcrank setup. Other than that, both planes will be built stock. And of course, tail wheels not nose wheels!
-Johnny-
Click for fullsize
Click for fullsize
       Post #: 11
RE: Dos Little Stiks - 8/27/2007 12:02:04 AM
jrbmoto
Status: online
Another pic
Click for fullsize
       Post #: 12
RE: Dos Little Stiks - 8/27/2007 1:27:30 AM
flightprep
Status: offline
Thanks for you post, we fly a Little Stik routinely - a real crowd pleaser. It has been in active rotation for about 3 years.
It was built from an original Midwest kit, nose wheel configuration with an OS .25 LA, 9x4 prop. It flies very well, and the .25 LA has ample power, but long or thick grass on the field can make takeoff dodgy. It's not super fast, but it is very aerobatic.
I am posting because I am thinking about builiding another Little Stik as a taildragger for winter use (with skiis), and have an OS LA .40 going spare - it seems a logical combination to me. However, to use a .40 LA, think about the following:
1. The nose wheel takes a lot of space in the forward compartment, so you have limited fuel capacity - therefore you can expect short filghts with a .40. If you go taildragger, you will have quite a bit more space under the hatch.
2. We mow grass with the 9x4 prop on a .25 - longer props e.g. on a .40 will make this worse, at least for a nose wheel setup
3. The stick is fairly heavy anyway, and while a .40 LA will give you plenty of power, you are adding quite a bit of weight vs. a .25 motor.
We've just finished a Sig Kobra and inherited another .25 scale plane, and based on the Little Stik experience are planning to get an OS .25 FX for the Kobra. The .25 FX would probably be ideal for the Little Stik as well.
Please let us know how you project goes, and good luck - you will enjoy this plane!
Brgds
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 13
RE: Dos Little Stiks - 8/28/2007 4:57:50 AM
jrbmoto
Status: online
flightprep,
Nice looking stik! I think I've decided what we're going to power these babys with. I did some homework and it seems that the GMS .36 has as much power as the OS .32 yet weighs 2 oz less and costs only $57.99 vs the OS at $124.88. I've had great luck with GMS motors in the past so I think this is what I will go with. I was going to go with an OS LA .40 but after comparing the two I think the GMS will be a better chioce. I do have an LA .40 so I might just buy one GMS to see how they compare in the planes before I buy two
(in reply to flightprep)
       Post #: 14
RE: Dos Little Stiks - 8/28/2007 10:48:25 PM
flightprep
Status: offline
hi jbrmoto,
Thanks for your update - the GMSs will have plenty of power. I would be very interested to hear how your Stik behaves at full throttle, as the stik wing is relatively thick.
Your plan to buy one GMS and try the other with the .40 LA is good, I am still planning a 'winter stik' powered by a .40LA, so would welcome a report on the .40 LA if you try it. With our nosegear setup and small fuel tank it just isn't worth the time and trouble to swap out engine mounts and try it myself!
I saw from your other post that you are going taildragger (good choice), and also duel aileron servos. We built ours with a single servo and bellcranks (partly because we wanted a 'period piece'); it is a good setup but 2 aileron servos is a better plan.
We are getting an OS .25 FX in any case as the Kobra engine bay is tiny - no room for anything bigger. We may break it in on the Stik, if we do I 'll let you know how that works.
Good luck with your builds, they lood great so far (and great looking Contender as well!).
Brgds
       Post #: 15
RE: Dos Little Stiks - 8/29/2007 12:18:41 AM
jrbmoto
Status: online
Hey flightprep,
Thanks for the compliments! This has really been a fun project. I'm amazed how quickly they're going together. Another cool thing about this kit is that it has s
