buzzard bait
Joined: 1/1/2003 From: Ithaca, NY, USA Status: offline
David, when I was teaching myself RC (with an 049 powered TF Schoolmaster, rudder and throttle only) I did not get comfortable with wind until I realized that I only got into trouble when I turned downwind. So learned to make 'S' turns ONLY into the wind, like the slope soarers do, and it completely solved the problem. You just keep winding your way toward the wind, and the wind keeps pushing it back into range. It means you don't suddenly go hurtling downwind and you never have to beat your way back upwind with the orientation problem working against you. In fact, it allowed me to get enough experience in wind that I could eventually deviate from it and still stay out of trouble. It's a real confidence booster, knowing that you can handle it. I think contrasting colors are worthwhile, but the truth is I have never found I could rely on visual cues. The only way to stay oriented is to trust that you know what you last did, so you know what the plane must be doing, no matter what it appears to be doing. But still, I agree with what you said about painting wing tips. Just don't expect it to really solve the problem. Jim
