Stick Bender
AR, USA Status: offline
Well my pace has slowed quite a bit from my jack rabbit start. I'm going to try to do at least one thing every chance I get. Tonight I made some holes for the aileron servo leads. I could not find any brass 1/2" tubing but they had aluminum. I put teeth on the end but decided I didn't want to hack the foam all up. The heating with a torch worked great, it melted right through leaving the foam sealed so it's a nice little smooth tube to run the leads through. The first one I hit perfect, or at least I got through the hole in the captivation rib, the second one I hit the edge of the hole but was close enough I just had to wiggle it a little to get it through the hole. Time to start sanding and get it ready to cover... I was wondering on the control horns, it looks like you glued the hard points and then the horns later? It seems like it would be easier to glue it all at once. I can see covering being a pain with the horns in the way. Maybe I should wait and put hard points and horns in after I cover it?
