Dual Disc brake question...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> Dual Disc brake question...
Page: [1]
Login
Dual Disc brake question... - 8/16/2007 11:17:42 PM
zud00
Status: offline
I have been running my savage X stock and my brake disc wore out and I had absolutely no brakes. So i decided to upgrade to the dual disc brakes. When I was installing them, after I screwed the screws into the transmission, i noticed it didn't turn. I figured once I put everything back together it would work just fine. Finally after getting everything back together, I put the truck on the ground and tried to push it and the brakes were locked up. I tried to adjust the brake linkage and it didn't do anything.
It looked like a tight fight when i put the discs and pads on but I thought it'd be fine.
How do i fix it so the brakes don't lock up like this? What do I need to do to release the tension on the discs?
_____________________________
Savage X w/LRP z28 spec 3
Bash Big or Go Home!!!
       Post #: 1
RE: Dual Disc brake question... - 8/16/2007 11:23:09 PM
ashburg
Status: offline
you loosen the 2 screws holding the brake disk assembly on - it's a bad design, just roll with it
quote:
ORIGINAL: zud00
Savage, Warhead, and Revo tip & trick compilations at www.ashburg.com
(in reply to zud00)
       Post #: 2
RE: Dual Disc brake question... - 8/17/2007 12:37:02 AM
zud00
Status: offline
If i loosen them, do you suggest any threadlock so they don't come undone?
(in reply to ashburg)
       Post #: 3
RE: Dual Disc brake question... - 8/17/2007 12:41:33 AM
ashburg
Status: offline
nope, just loosen them a hair - just enough to let the brakes spin free
quote:
ORIGINAL: zud00
(in reply to zud00)
       Post #: 4
RE: Dual Disc brake question... - 8/17/2007 12:52:31 AM
RLMHPI
Status: offline
Its like nobody put any thought into stopping the Savage when they designed it!!! Have you guys tried the new Fiberglass dual disk brakes?? I have installed them but not ran my truck yet !!
       Post #: 5
RE: Dual Disc brake question... - 8/17/2007 12:58:44 AM
mazdab2600
Status: offline
the new dual fiberglass hpi #87025 kit
there's a suggestion on other forums to put ca glue on the circumfrence/edge. apparently the fiberglass starts to shred apart.
< Message edited by mazdab2600 -- 8/17/2007 12:59:33 AM >
f4.6/lrp spec3/piccop3.26 monster/picco p3.28/axial spec1.28
byrons 30%5 trucks.savage strong you bet.
(in reply to RLMHPI)
       Post #: 6
RE: Dual Disc brake question... - 8/17/2007 1:00:51 AM
itspuddingtime00
Status: offline
The dual discs stop my savage just fine. The only thing is I had to replace the pads once because they were worn down to the metal plates.
       Post #: 7
RE: Dual Disc brake question... - 8/17/2007 1:06:18 AM
ashburg
Status: offline
the dd fiberglass are THE best I've tried...versus the dd stainless steel, I like the fiberglass way better because they don't bend.
quote:
ORIGINAL: RLMHPI
       Post #: 8
RE: Dual Disc brake question... - 8/17/2007 1:38:01 AM
RLMHPI
Status: offline
Sounds good I cant wait to try them I will keep my eye out for fraying of the fiberglass .
       Post #: 9
RE: Dual Disc brake question... - 8/17/2007 6:57:49 AM
Flib
Status: offline
i`ve got 2 mates with the new 4.6 x which has the fiberglass duel disks and they have both shredded theirs and replaced them with the stainless steel ones
       Post #: 10
RE: Dual Disc brake question... - 8/17/2007 7:00:33 AM
SpikeX
Status: offline
I have the stainless steel Dual Disc Brake Set on both my Savages, and I've been extremely happy. Braking is incredible (4 flips if I brake too hard), and I've never had to replace the pads in over 6 months. They don't actually fade as much as most people think, too...
(in reply to Flib)
       Post #: 11
RE: Dual Disc brake question... - 8/17/2007 7:21:40 AM
-SomeGuy-
Status: offline
quote:
ORIGINAL: SpikeX
Pretty much the same for me.
(in reply to SpikeX)
       Post #: 12
RE: Dual Disc brake question... - 8/17/2007 12:28:34 PM
ashburg
Status: offline
I've landed so hard that I've bent the DD stainless steel disks, see pic...hence, my preference for the dd fiberglass
quote:
ORIGINAL: SpikeX
Click to see fullsize image.
Click for fullsize
       Post #: 13
RE: Dual Disc brake question... - 8/17/2007 12:56:27 PM
(X)
Status: offline
damn that's nasty,
What happened?
There are no stupid questions, just stupid people.
       Post #: 14
RE: Dual Disc brake question... - 8/17/2007 2:08:26 PM
ashburg
Status: offline
What happens with the dd steel is that if you land on all 4's from like 20' high with the brakes engaged, they bend - especially if they're heated up from use already. They were already bent up as described the day I did this...I had bent them back into place with pliers, which worked for the time being...
What actually happened in that pic to splay them out like that was the clutch bell got rammed into the brake assembly - because I landed on the engine head . I should have just stopped banging on the truck when the brakes were compromised because I had no control of the flight of the truck.
anyway, call it all driver error and (my) stupidity, but I'm liking the fiberglass because they're more foolproof IMO
quote:
ORIGINAL: (X)
damn that's nasty,
What happened?
(in reply to (X))
       Post #: 15
RE: Dual Disc brake question... - 8/17/2007 3:12:33 PM
RLMHPI
Status: offline
HHmmmmm mixed opinions I have the stainless dual disks too I guess if the fiberglass dont hold up I will go back to the stainless!!
       Post #: 16
RE: Dual Disc brake question... - 8/17/2007 3:14:57 PM
rcnitrohead
Status: offline
Makes sure that you DO apply threadlock to the DD brake
