2 speed transmission
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> 2 speed transmission
Page: [1]
Login
2 speed transmission - 8/17/2007 1:58:11 AM
yamahauler236
Status: offline
Do any of you people know if a traxxas jato 3.3 2 speed transmission will fit in my losi xxx nt? Thanks
       Post #: 1
RE: 2 speed transmission - 8/17/2007 2:43:19 AM
neilt6
Status: offline
You could probably make it fit in one way or another. You can make anything fit if you have access to a dremel, drill press, and lathe!
(in reply to yamahauler236)
       Post #: 2
RE: 2 speed transmission - 8/17/2007 2:44:40 AM
jatoracing33
Status: offline
jato tranny sucks period. tear up 2nd speed with every set of donuts.
_____________________________
92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
(in reply to neilt6)
       Post #: 3
RE: 2 speed transmission - 8/17/2007 3:07:03 AM
yamahauler236
Status: offline
sorry but i like 2 speeds. Will the dremeling make the tranny weaker? Also is there an aluminum version of the 2 speed tranny? Thanks
(in reply to jatoracing33)
       Post #: 4
RE: 2 speed transmission - 8/17/2007 3:14:18 AM
jatoracing33
Status: offline
if there was an aluminum version of the jato tranny i would be the 1st one in line to buy it, but there aint, so be it. i dont think dremeling will do any harm, as long as the gears stay safe
       Post #: 5
RE: 2 speed transmission - 8/17/2007 5:54:37 AM
yamahauler236
Status: offline
ok thanks if any one has a used one the will sell tell me i need a cheap one incase it dosnt fit. I dont think there will be a problem my dad is a machinest in a big plant so he welds and works with any tool in a metal factory you can think of. Hes a handy man.
< Message edited by yamahauler236 -- 8/17/2007 5:55:37 AM >
       Post #: 6
RE: 2 speed transmission - 8/17/2007 6:33:34 PM
neilt6
Status: offline
I'm planning on fitting an NTC3 2-speed tranny on my GT2, all I have to do is shorten the TC3 shaft to a bare minimum and drill a flat sided hole down the middle, then I can slip a rear slipper pad (To drive the brake disk), a washer (To keep the pad from touching the 2 speed gears), my assembled 2 speed setup, and a nut onto the stock diff shaft!! And the TC3 clutch bell fits on the GT2 clutch so it's brilliant!!!
       Post #: 7
RE: 2 speed transmission - 8/17/2007 7:37:44 PM
yamahauler236
Status: offline
How different are the gt2 and xxx nt tranny? Would that work on my xxx nt?
       Post #: 8
RE: 2 speed transmission - 8/18/2007 5:39:22 AM
neilt6
Status: offline
I dunno. You'd probably have to look at them side by side in the store, but it might work...
       Post #: 9
RE: 2 speed transmission - 8/18/2007 5:53:56 AM
yamahauler236
Status: offline
ok
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.500RCU5
