Futaba transmitter question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> Futaba transmitter question
Page: [1]
Login
Futaba transmitter question - 8/17/2007 6:59 AM
mesaflyer
Score: 120
Last Login: 5/8/2013
Status: offline
I have a Futaba 4YBF transmitter. Went flying last weekend. I installed a freshly charged battery and when I turned on the transmitter, both the red and green lights came on. The manual says to replace ( or I presume re-charge) the battery when the red light flashes. I removed the battery and installed a different, freshly charged battery. Turned on the switch, and both lights were on again. Everything seemed to be working properly, so I did a range check with the antenna retracted, out to at least 150 feet, and everything was working properly. I went ahead and flew five times with no problems. I then changed the batteries in the radio and receiver. Flew four more times, with no problems. I e-mailed Futaba on Monday, but they have not responded. So, has anyone ever had the same problem with this model radio? Any suggestions on what I should check? And by the way, in the past, I have ran the transmitter battery down to the point that the red light started flashing.
Peter
Hide Signatures
       Post #: 1
RE: Futaba transmitter question - 8/17/2007 7:53 AM
Ferocious Frankie
Score: 100
Last Login: 5/18/2013
Status: offline
There is nothing wrong with your radio. When the transmitter's battery is fully charged, both the red and green light should be on. When the battery runs out, the green light will go out and the red light will remain. That is when you should charge.
_____________________________
Plane: AW 50cc Extra 300
Radio: Futaba 12FG 2.4 GHz
Hide Signatures
(in reply to mesaflyer)
       Post #: 2
RE: Futaba transmitter question - 8/17/2007 2:44 PM
CGRetired
Score: 221
Last Login: 5/20/2013
Status: offline
There's nothing confusing about that, now is there..
Skylark 70 - OS .75 AX; Excelleron 90 - OS 1.20 AX; Venus II - OS 1.20 AX; And, I still fly my trainer, Hanger 9 Alpha - OS .46 FX! Some electrics. Airtronics RD8000 - Spektrum DX7 - DX6i. AMA 705964.
Semper Paratus!
Hide Signatures
(in reply to Ferocious Frankie)
       Post #: 3
RE: Futaba transmitter question - 8/18/2007 12:31 AM
Ferocious Frankie
Score: 100
Status: offline
red+green=good
red+0= not good (charge)
Hide Signatures
(in reply to CGRetired)
       Post #: 4
RE: Futaba transmitter question - 8/18/2007 3:19 AM
mesaflyer
Score: 120
Status: offline
quote:
ORIGINAL: Ferocious Frankie
red+green=good
Thanks for the help. I finally looked at Futaba's FAQ and found the same answer. So everthing is good. I just seem to remember that the red light was not on before, just the green. And the red would start flashing when the battery got low. Guess I screwed up
Thanks again.
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.312RCU1
