gcb
NY, USA Status: offline
quote:
ORIGINAL: 500 lb. koolaid man Thanks for the info, burtcs. -Do you know how people even hook up exhausts to these engines? The first I had with an enclosed exhaust was a "QZ". I think the cylinder was removed, the muffler put on, and the cylinder reinstalled. Some throttled versions had the cylinder machined and the throttle sleeve was installed by removing the cylinder, inserting the throttle sleeve, then reinstall the cylinder. The Tatone muffler came in two parts which were screwed together over the cylinder (without removal). All this is from memory so it may be a bit inaccurate. quote:
-Do you know if my engine is anything special? Is that a built in tank on the e-bay engine? Thanks for the info so far on that engine, you tout me a lot of things I didn't know[ It appears to be a standard later model Babe Bee, before they went to the plastic backplate tank. The fill nipples (with the green tubing) extend only into the tank cavity. If flown inverted fuel will spill out a bit. Either nipple can be used to fill, the other will vent. Later models had one fill nipple, the other a small hole for venting. quote:
-I've been running my .049(only once or twice) with 20% car fuel. I know the manufacturers recommend "1/2A fuel" I now have a gallon of 15% plane fuel, will that be ok for the engine? Beware of car fuels. Some of them have very little lube because they are run at high RPM under light loads and do not need as much lube. The plane fuel may need some castor oil added because of the ball-socket on the upper end of the connecting rod. That area gets VERY hot if run lean and some synthetics will "flash" off and lose lubrication. It will run OK on 15% nitro. The oil is the questionable quantity. quote:
Ok, that's the last of my questions. Thank you very much. WHEW!! George
