1/4 throttle needed to start
Tower Hobbies
Logged in as Guest
  Printable Version
HPI Racing Baja 5B - RTR
Seller:  lisa2803
Details:   $799.99   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> 1/4 throttle needed to start
Page: [1]
Login
1/4 throttle needed to start - 8/17/2007 1:30:06 PM
zud00
Status: offline
I've ran two gallons through my 4.1 rtr savage. Recently, when starting I need to give it 1/4 throttle to start. If i let off it will die. After starting, I do a few warm up runs, but if I let off the throttle it dies.
After it is completely warm and i am through 1/4 of the tank of fuel, I can get completely off the throttle and it idles just fine.
What do I need to do so that I don't have to give it throttle to get it started?
_____________________________
Savage X w/LRP z28 spec 3
Bash Big or Go Home!!!
       Post #: 1
RE: 1/4 throttle needed to start - 8/17/2007 1:38:08 PM
Ev1er
Status: offline
Turn the Speed idle 1/4 clockwise.
The you should be ok
You can also turn the HSN Highspeed needle clockwise 1/8.
Hopes this helps a little:P
|Basher:Traxxas E-Revo - MambaMonster 2200 - 6s 5000mah lipo | :: |Drifter:Tamiya TB02D - MambaMax 5700 - 2s 8000mah lipo |
(in reply to zud00)
       Post #: 2
RE: 1/4 throttle needed to start - 8/17/2007 4:15:55 PM
zud00
Status: offline
By turning the idle needle clockwise, wouldn't that give the carb less fuel? I am needing to give it more fuel to start, so that wouldn't make any sense.
(in reply to Ev1er)
       Post #: 3
RE: 1/4 throttle needed to start - 8/17/2007 4:33:13 PM
Nick2618
Status: offline
I think it is counter clockwise for more fuel and yes thats what you wnat to do.
Florida Gods Waiting RoomCheck Gallery for Pictures
Jato 3.3 |Cen Nemesis (working...) |Lunchbox |ST-15 |Mario Kart D
(in reply to zud00)
       Post #: 4
RE: 1/4 throttle needed to start - 8/17/2007 5:45:20 PM
46u
Status: online
Keep in mind that nitro engines can require retuning day to day or even during the day if you have weather changes. Now many times you will have to give a little throttle to start a cold engine and is why high end radios have an idle up function. Even when starting a 1 to 1 car cold they have a fast idle till warm.
Rebel Racing, Sponsored by, Byron Fuel Looking for a new engine sponsor!
(in reply to Nick2618)
       Post #: 5
RE: 1/4 throttle needed to start - 9/5/2007 4:15:55 AM
zeddfirstwizard
Status: offline
I do the same thing just turn the gain on then after it starts up turn it back done this for years
(in reply to 46u)
       Post #: 6
RE: 1/4 throttle needed to start - 9/5/2007 3:51:16 PM
av8torjim
Status: offline
If I understood ev1er correctly, he meant the idle speed screw, not the low speed needle. He's recommending that you open the throttle slightly with the idle screw rather than the throttle servo. At crank starting speeds, you aren't giving it more fuel when you open the throttle, you are adding more air, i.e., leaning the mixture. At crank speeds you aren't really drawing much fuel. If you want to adjust the LSN, you probably need to lean it (clockwise on most carbs). Check the setting with the pinch test to confirm.
(in reply to zeddfirstwizard)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU5
