RECOMMEND THE BEST STILL/VIDEO CAMERA FOR SMALL ELECTRICS
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Aerial Photography and Video >> RECOMMEND THE BEST STILL/VIDEO CAMERA FOR SMALL ELECTRICS
Page: [1]
Login
RECOMMEND THE BEST STILL/VIDEO CAMERA FOR SMALL ELECTRICS - 8/17/2007 2:32:33 PM
kingaltair
Status: offline
This is my first try on this forum, and I'm out of my area of expertise here--so be patient.
I'm sure this has been asked before, but I'm looking for recommendations for photo gear that is small/light enough to be used with a small(39" , electric (Ultra Stik) for a search/rescue operation to find a lost plane. It needs to have good enough resolution to be able to pick out a plane from above some very rough country where my plane "went in". I have tried in vain to find the plane, even from a helicopter, but it's "out there."
I originally was thinking of a small digital camera, but a wireless video will probably work just as well or better. It needs to be relatively affordable as well. Any recommendations, will a small plane like that be able to carry the equipment, and how should everything be mounted.
I'd appreciate any help from the video/camera experts as to what is available, is affordable, and works. I saw something at a Radio Shack for around $175 complete with 380 resolution lines with supposedly a 300' range. Is that enough to give the resolution necessary to find a plane?
       Post #: 1
RE: RECOMMEND THE BEST STILL/VIDEO CAMERA FOR SMALL ELE... - 8/21/2007 4:49:00 PM
Mcgiver
Status: offline
Hello, Mcgiver here . I just happened upon your post and I saw a guy this past Sat. that had a small digital movie camera attached to his electric foamy bi-plane and it did a great job filming the flight line at the fly-in. He said you can buy them at CVS pharmacys or Rite-Aid for $20 to $22 and take the camera out of the case and mount it to the bottom of your plane, attached to the reciever through a servo slot. You have to do a little soldering on the camera circuit board to connect the servo wire but its a cheap way to go.
I hope this helps you in some way.
Mcgiver
(in reply to kingaltair)
       Post #: 2
RE: RECOMMEND THE BEST STILL/VIDEO CAMERA FOR SMALL EL... - 8/23/2007 2:44:46 AM
akouzmit
Status: offline
Another choise: http://www.rcuniverse.com/forum/m_6062814/tm.htm with video clip sample, camera review and place to buy.
Andrew.
(in reply to Mcgiver)
       Post #: 3
RE: RECOMMEND THE BEST STILL/VIDEO CAMERA FOR SMALL EL... - 8/23/2007 7:45:55 AM
JMSTECH
Status: offline
Ever tried out Rangevideo, futurehobbies etc.. for a KX151 with 500mW video TX/RX? If you buy cheap stuff, you will realize that you wasted your money because of regrettable results. Happened to me!
(in reply to akouzmit)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU5
