argument
Tower Hobbies
Logged in as Guest
  Printable Version
Advantage 2x2 meter F3A Pattern - RTF
Seller:  dbarrym
Details:   $1,250.00   |  12/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Pattern Flying >> argument
Page: <<   < prev  1 2 [3]
Login
argument - 3/22/2003 12:09:21 AM
TOYMAKER
Status: offline
LIKE the header says on this link.
"HOW TO START AN ARGUMENT"
Just dont flop a Stall/Hammerhed turn .... you'll get zero'd everytime.
(in reply to Rossan)
       Post #: 51
How to start an argument... - 3/22/2003 12:11:38 AM
JimTrainor
Status: offline
Flop? You mean fall out off axis?
       Post #: 52
flop - 3/22/2003 12:26:30 AM
TOYMAKER
Status: offline
exactly...
generaly the plane will pitch forward or back on a flop instead of yawing left or right... did I say that right? I think so.
       Post #: 53
How to start an argument... - 3/22/2003 4:32:19 AM
Rossan
Status: offline
Luke,
The point of the thread wasn't to argue about the name of a maneuver, but to point out a fairly common mis-conception about the principle of what constituted a stall.
From your reply I suspect you share this misconception. An aircraft does not "Lose all lift" when it stalls. t reaches a point where increasing angle of attack reduces the lift it produces, but it doesn't just stop lifting. Many 3D style maneuvers take advantage of this fact. Ia a Harrier for example, the aircraft is stalled, but a combination of the little lift the wing still produces and the upward vector from the thrust allows the aircraft to keep flying at a high angle of attack.
_____________________________
I'd rather be down here wishing I was up there than up there wishing I was down here!!
       Post #: 54
This should settle it... - 3/22/2003 7:57:55 AM
Ben Diss
Status: offline
IAC OFFICIAL CONTEST RULES
Chapter 8 - Criteria for Judging Aerobatic Figures
Family 5 - Hammerheads
Hammerheads, also referred to as stall turns, are some of the most graceful figures in the FAI Aerobatic Catalog. In its most basic form, the figure begins when the aircraft leaves horizontal flight and flies a quarter loop to establish a vertical climb. At the top of vertical line, the aircraft pivots and establishes a vertical descent, with the figure ending as the aircraft is returned to horizontal flight.
       Post #: 55
How to start an argument... - 3/22/2003 3:11:51 PM
robert
Status: offline
Guy's, I really cannot stop laughing at this thread.
       Post #: 56
How to start an argument... - 3/24/2003 6:25:09 AM
Rendegade
Status: offline
Robert: I'm glad that someone see the fun side of it.
Guys and girls don't get me wrong, I've been BBLing it for years, I've never been an internet warrior, I always read everything with a grain of salt and there's nothing I like more than a good (even if it is on whether dark toast is better than light toast) argument to while the day away.
I really don't care if we never get to the bottom if this, but hey, at least it's a popular thread
Toymaker? I take it when you mean a flop you mean, to stop the aircraft and then have it fall over? Ie it's airspeed is zero when it gets to the top? then yeah, you're right, it's not a zero airspeed maneuvre.
Don't forget that a snap roll is also a stalled maneuvre, but you're not travelling at zero airspeed, are you??
It's easy to fly, just throw yourself at the ground and miss!
       Post #: 57
How to start an argument... - 3/24/2003 4:13:30 PM
Rossan
Status: offline
No, you're not at zero airspeed, but you're not at zero "G" either. Stall speed varies as the square-root of Load Factor ("G" , so by subjecting the aircraft to a vertical acceleration, you increase load factor and therefore stall speed. This is know as an accelerated stall, and is how auto rotative figures like snaps are achieved.
Confused yet?
(Edited because I don`t know a square from a root...only Aussies will get that one: )
< Message edited by Rossan -- Mar 25 2003 6:15AM >
       Post #: 58
How to start an argument... - 3/25/2003 5:54:27 AM
Rendegade
Status: offline
No no not at all.
I'm aware of high speed accelerative stalls.
I was simply trying to point out that not all stalls occur at low airspeed.
Are we getting off topic now? Do we care?
Is it time for a tangential shift??
       Post #: 59
How to start an argument... - 3/25/2003 2:26:40 PM
Rossan
Status: offline
No, not off topic. In fact re-enforcing the point I was making. You don`t have to be at slow speed to stall, neither do you have to be stalled just because you`re at slow speed.
Still, we`ve done this one to death... Next I think I`ll risk stoning as a heretic and suggest that benouli is an inacurate explanation of lift...GASP!
       Post #: 60
How to start an argument... - 3/25/2003 10:45:16 PM
Ben Diss
Status: offline
Bernouli is only part of the story. Read this:
[URL=http://www.monmouth.com/~jsd/how/]See How It Flies[/URL]
-Ben
       Post #: 61
How to start an argument... - 3/26/2003 5:42:59 AM
Rendegade
Status: offline
Rossan, if you say that, out loud, I'll be right behind you.
Bernoulli doesn't really gel with me...
       Post #: 62
Jump to:
Google
Search | Marketplace | Event Calendar |
