flyinGraham
Joined: 2/23/2006 From: Wirral, UNITED KINGDOM Status: offline
quote:
ORIGINAL: pliebo I kind of like the red white and blue scheme, but can't decide. I'm on the list but I told her I wanted the yellow blue one. I ordered my 25mm drop hdr, and 5955's, now all I need is spinner( what size?) and servo extensions,(what length?) I'm thinking 2-36" for elev, 2- 24" for ail, and 2- 12" for throttle and ign? does this sound right? also how do you add smoke to the cannister setup, do you tap the header or the cannister? and can a 50cc bird carry the extra weight of smoke system? I heard it's better for 33% and up. opinions? thanks, Phil. Thats set up will be perfect mate. The spinner size is 4" for the extra. I will have to measure the extension leads to tell you what I used, so I will do when I get a chance, unless Nick has some measurements in mind?? I don't know anyone who is going to use smoke, but I imagine that a 50CC engine could cope with the extra weight although it will fly far better the lower the weight due to a much lower wing loading, so it is entirely up to the individual whether they use smoke or not. If its like all of the other EF stuff I have flown, I imagine it will feel alot bigger in the sky than what it actually is, I have found this a consistant trait with the EF stuff, even in the smaller electric models they sell.
_____________________________
Graham Roscoe
