yarom
Joined: 6/23/2005 From: Bellevue, WA, USA Status: offline
DA-50, hands down. That stuff about the ZDZ 50 being stronger is crock. Never seen a ZDZ swing bigger or faster than a DA. The DL is identical to the DA in all aspects except price and service. While transition is better with the DL at the beginning, after break-in and change of oil, the DA is better than the DL in my opinion. It also swings faster and could swing larger (24x8). Tried both on the same plane, all through break-in and ended up with the DA capable of delivering 7K rpm on Mejzlik or NX 23x8... quote:
ORIGINAL: pliebo I know this is off topic too, but, I'm thinking of getting a new engine for this plane, when you look at the spec's, the ZDZ 60 looks pretty good, and the brillelli 60 looks good too. please bear in mind these specs are just approximations offered by chief aircraft, and everything but brillelli are weights without muffler and ign. 3W50--- 4.8hp--- 8700rpm--- 4.36lbs--- $565 3w55i --- 6.5hp--- 8700rpm --- 4.2lbs --- $520 Evo58--------- 7500 rpm --- 4.25lbs ---- $599 ZDZ50ng--- 5.7hp --- 7000 rpm --- 3.36lbs --- $650 ZDZ 60 --- 5.4hp --- 8200 rpm --- 3.96lbs --- $675 DA 50 --- 5.0 ------ 2.94-3.13 --- $595 brillelli 60 ------ 7500 --- 4.18rtf --- $595 I am looking for something that is light, runs strong with reliable idle, and no problems running inverted or all other attitudes, which one would you pick?
