RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Tower Hobbies
Logged in as Guest
Users viewing this topic: mcmike, Jake Ruddy, kretov
  Printable Version
AeroWorks Extra 260 50cc Xlnt Condition - ARF
Seller:  talon58
Details:   $500.00   |  9/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan... - 8/29/2007 2:06:46 AM
panicman
Status: offline
It was mentioned in one of the yak threads that a 78" extra may be comming, it that still a possibility?
(in reply to TomG3D)
       Post #: 51
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan... - 8/29/2007 2:29:53 AM
nitro wing
Status: offline
Really? that would be an odd size,kinda big for nitro ,and kinda small for real gas,Maybe a 160 size brother to the 160 size Yak?
I am really liking this 88.5
Even with a new DA it seemed to have Foamy Pullout
I like what I see so far
(in reply to panicman)
       Post #: 52
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/29/2007 2:58:02 AM
Richard D Bahmann aka/Wrongway
Status: offline
Nitro, the DA fiddy and pipe ought to be giving near 32-34 lbs of thrust on a 16 (16.75 lb mayby with fuel) airframe. You are approacing the 2 to 1 power curve. That is cool in my book!!
Now all I would like to see is the red, the blue and the red/blue scemes side by side to decide.
I am thinking DL-50 on Ecomposites tuned pipe with a single 2 cell A123 on flight and a single cell A123 on ignition. The Bisson type fiberglass spinner is a pain in the long run wit the 6 screws to set (I would like to find a light white...most likely glass spinner with that shape).
I have owned/flown (see my models) what may very well be a distant cousin of this plane with 85 inches and 16 lbs and I thought the design with enlarged flight controls was pretty cool and it did the most wicked KE spins. I can only imagine this one which is midwing (better)and the biggest plus for me is the pipe tunnel.
Guys I have the EF-88 Yak and love the sound and power of a piped engine. If the competetors were smart they might figure out the added marketability of pipe/canister accomodations.
Richard
_____________________________
Gonna kick the tire and light up my
Torch...Gone Flying...WrongWay
(in reply to nitro wing)
       Post #: 53
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/29/2007 8:36:05 PM
TomG3D
Status: offline
It hovers at UNDER half power, on a DA with about 3 tanks through it !
Ive actually got a 2s2p on RX of 3000mah and a 2100 2s1p on igntion,
Works a Treat.
Havent had a weigh in yet.
Soon tho !
Team Extreme UK -- Any Questions about any of your EF Products ? MSN -- freestyle-rc@live.co.uk
       Post #: 54
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/29/2007 9:48:45 PM
EXTREME FLIGHT
Status: offline
Here is a photo of the alternate color scheme for the 88 inch Extra. This is the 58 inch version but the scheme is the same. Pilot and dash/panel as well as Depron cockpit floor are included, but not installed. We have opted to use this scheme vs. the blue/white as we were having trouble with orientation, especially on the back side of rolling circles.
Click to see fullsize image.
Click for fullsize
EXTREME FLIGHT RC
State-of-the-art Aerobatic Aircraft and Accessories
       Post #: 55
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/29/2007 10:04:35 PM
cadconversions
Status: offline
quote:
ORIGINAL: EXTREME FLIGHT
Not bad at all, of course, change the blue to black and you've got the same scheme (almost) as the yak. I really like it and the multicolored scheme is totally awesome.
Kevin
(in reply to EXTREME FLIGHT)
       Post #: 56
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/29/2007 10:55:25 PM
Whirlyspud
Status: offline
I like it!
Mike
(in reply to cadconversions)
       Post #: 57
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/29/2007 11:18:36 PM
yarom
Status: offline
Getting there Chris - almost perfect.
The last upgrade missing would be a cowl with a inner ply ring that attaches to the firewall with 4 bolts - like the Aeroworks and PAU models.
Alignment to fuse is perfect every time and there is less wear on them holes in the FG cowl.
       Post #: 58
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/29/2007 11:22:29 PM
Rush7
Status: online
Chris, any update when these beast will hit the good ole U S of A? I think the yellow and blue is even better than the blue and white.
I had a little trouble with orientation with the 45" blue and white at first also.
Keep up the great work.
http://www.crccflyers.org
Huckin' til it hurts
(in reply to yarom)
       Post #: 59
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/29/2007 11:29:51 PM
cadconversions
Status: offline
quote:
ORIGINAL: yarom
Totally agree. A cowl ring mounting system would be awesome!
Kevin
(in reply to yarom)
       Post #: 60
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/30/2007 12:19:55 AM
DLEVETT
Status: offline
Both of these schemes are spectacular! What a truly awesome job you guys [ Extreme Fight & Freestyle-RC] have done bringing these planes to the market, the bar just keeps getting raised higher and higher.
thx Dave
       Post #: 61
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspa... - 8/30/2007 1:40:31 AM
Status: offline
Chris, what would the underside look like for the wing bottom? I really like the large rectangles like on the posted earlier in this thread (red and white underside)
RDB
       Post #: 62
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingsp... - 8/30/2007 6:07:22 PM
EXTREME FLIGHT
Status: offline
The bottom is solid blue with yellow invasion stripes. This provides a great contrast to the yellow top. These Extras have been in production for several weeks and I am sure I will get the shipping notification soon.
EXTREME FLIGHT RC
       Post #: 63
