JoeAirPort
WI, USA Status: offline
I admit that early on I was dissappointed with the weight. I weighed it all out of the box and knew it was going to be over 18 pounds. Mine is 17 pounds, 15.5 oz without the pilot and instrument panel. It has a B60 with stock muffler. Has one 7.2 oz rx battery and a one ounce 1-cell lipo ignition battery. It flies great, Chris has given me stellar service. Even knowing the real weight, I still would have bought it. I can understand your frustration hoping for something 16.5-17.5 pounds. I was too but I just got over it and decided not to make a fuss. I'm very happy with the plane. I'm just glad I have a B60 and not a 50cc engine. Your DA is turning low numbers, that could be adding to your frustration. That 23x8 prop is too much for break in. Try a 22x8 until it's broken in. Also you may be running way too rich. First change props then re-tune. You will be happier with the 22x8. Also any 50cc engine is going to need a pipe to pull an 18 pound plane. It amazes me that someone can have a 16.3 pound plane and someone else a 18.3 pound. Where does 2 pounds come from? It's only a 50cc plane.
< Message edited by JoeAirPort -- 5/8/2008 4:11:08 AM >
_____________________________
Joe AP
