RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
$3,800.!!Yak 54 Competition version !!! - ARF
Seller:  tavis newman
Details:   $3,800.00   |  9/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Page: <<   < prev  34 35 [36] 37 38 39 40 41 42 43   next >   >>
Login
RE: Extreme Flight E... - 5/14/2008 10:52:56 PM
TomG3D
Status: offline
and your right, i find the ES not too peaky, of course its going to be peaky cause firstly its a petrol and secondly its a tuned pipe, but the ES seems to be bang on!
_____________________________
Team Extreme UK -- Any Questions about any of your EF Products ? MSN -- freestyle-rc@live.co.uk
(in reply to TomG3D)
       Post #: 876
RE: Extreme Flight E... - 5/14/2008 11:01:54 PM
6Packo Beer
Status: offline
Hey Tom, Whats the weight of your 50cc extra with the ES Pipe ? I was considering going with the pipe 4 extra power b/c my bird is comming in a bit fat.
Thanks.
       Post #: 877
RE: Extreme Flight ... - 5/14/2008 11:16:24 PM
TomG3D
Status: offline
ill find out for you dude.
although mine wont be accurate as it was the prototype model, and there is no cockpit, and a fair bit less structure in mine to the production kits, ill find out nonetheless
(in reply to 6Packo Beer)
       Post #: 878
RE: Extreme Flight ... - 5/14/2008 11:23:07 PM
6Packo Beer
Status: offline
if the kit is different never mind, what was lightened ? The fire wall or something, i am looking for any way to cut weight. Also any advice on using or setting up that ES Pipe, any major headaches / problems u had ?
       Post #: 879
RE: Extreme Flight ... - 5/15/2008 1:51:57 AM
3DAP
Status: offline
6 Pack,
Have you got any R's out of your DA yet?
       Post #: 880
RE: Extreme Flight ... - 5/15/2008 1:58:30 AM
xtraflyr
Status: offline
If your not getting the right RPMs,dont worry about the weight.. Were telling you it's not going to matter. Its gonna fly AWESOME!!!
www.njjf.org
www.njjf.freeforums.org
(in reply to 3DAP)
       Post #: 881
RE: Extreme Flight ... - 5/15/2008 3:20:17 AM
6Packo Beer
Status: offline
I talked to DA, they said the slimline pitts muffler will kill 2 - 300 RPM's off the bat, I have a mejlik 23x8, they recommend a Vess 22A for break-in then the 23x8. I am waiting for the prop should be here friday. If the weather is good sat I hope to fly hopefully with a few hundered more RPM. If thr RPM still suck with the 22 A on there I will call DA back and see about sending the engine to them for a once over b/c even they said 6050 rpm - 6250rpm on a 23x8 is way low for a DA even one that aint broke in. Im not worried this is why i bought a DA, if it aint right the'y'll fix it.
> with the down time im giving the airframe a solid look to make sure all links / wires / whatever are A-Okay, dont want to lawn dart b/c of a $5.00 part.
> Also Chris at EF told me most people are comming in at 17.5 - 18 pounds with this airframe , so if your under 17.5 consider yourself lucky.
< Message edited by 6Packo Beer -- 5/15/2008 3:22:40 AM >
(in reply to xtraflyr)
       Post #: 882
RE: Extreme Flight ... - 5/15/2008 3:28:17 AM
Jake Ruddy
Status: offline
LIke I said at 18 pounds this thing has 28.6 oz wingloading... thats nearly foamy type wingloading for a plane this size. Ok I am stretching it a bit but find my another plane this size with that type of wingloading....
       Post #: 883
RE: Extreme Flight ... - 5/15/2008 4:18:49 AM
JoeAirPort
Status: offline
6packo...I don't remember you talking about tuning that DA (or I missed it). Did you lean that low needle to get the 4-stroking out of it? If it's running fat in the midrange it will run fat in the high. Where are your needles at? I have spent lots of time tweaking my DA 50 and got very good results. I'd just like to get an idea where your needles are adjusted so maybe I can help. Mine liked to be around 2 turns out high and anywhere from 1 1/8 low or 1 1/4 low depending how cold it was out. I always left the high needle at 2 and just leaned the low for a really good transition and midrange....then the high RPM's always went up with the low needle. It always tuned out really well on the high by only adjusting the low.
The other thing is that if you have your high needle too lean, that peak RPM will suffer. It usually drops when it's too lean, you can hear it. Let me know what it sounds like peaked. Does it drop RPM's after a few seconds or does it hold a steady at WOT? If it rises slowly it's usually too rich but normally the DA 50 can't be too rich unless they changed the carb's (doubt it).
Joe AP
(in reply to Jake Ruddy)
       Post #: 884
RE: Extreme Flight ... - 5/15/2008 4:44:19 AM
3DAP
Status: offline
Joe,
What spinner did you go with after the plastic one broke. I am going to send plastic one back and hope it works as a down payment for a carbon prop. I finally got an email back from NO LIMITZ spinners and props. I am going with one of their 4 inch carb spinners. It took me a while to get a response from them but its in the works. I got cowl on the way I like it, just a .125 over the former and it fits perfect. It took a lot of messsing with though. After I started cutting it went better. Module is mounted working on switches and then on to gas tank. Working so much has made this take way to long, also polishing landing gear to chrome finish took too long. Everything with me takes way to F*&*&n long.
How is your's flying? Where are you happy with cg at????
3DAP
(in reply to JoeAirPort)
       Post #: 885
RE: Extreme Flight ... - 5/15/2008 8:57:55 AM
TomG3D
Status: offline
ES pipe is great dude. stick a 13inch header on there, Silicone high temp joiner as teflon always slips off and a jubliee clip on the tuned pipe end of the joiner, works great.
it gets really really hot, so make sure you mount it effectively.
quote:
Joe,
Just get out and fly it and let it put a smile on your face!!!
My CG is on the middle of the wingtube! bang on !
I used the no limitz for about 4 weeks as you saw from the original piccies from the inital flights, the silver carbon one. and it failed. Threads for the screws stripped THEMSELVES! in flight and bits of the cone started to break up, i took it off before it failed but noticed it quickly.
I know of several others that also failed one of which almost killed the model.
Not saying there a bad product, just stating ive seen several go wrong in a short space of time
Mejzlik all the way!!
(in reply to 3DAP)
       Post #: 886
RE: Extreme Flight ... - 5/15/2008 11:58:29 AM
wavy777
Status: offline
quote:
ORIGINAL: 3DAP
Joe,
3DAP
3DAP, I agree with Tom, ES composite pipe is fantastic, I'm on a 12" header. As for spinners, I always get mine from TBM as per
http://troybuiltmodels.com/SpinnersAL.htm#mpi nice and light, good value and looks great.
My CG is at 6.5", perfect...
(in reply to 3DAP)
       Post #: 887
RE: Extreme Flight ... - 5/15/2008 1:51:49 PM
Jake Ruddy
Status: offline
www.petemodel.com
I always use his spinners and they have never failed me.
(in reply to wavy777)
       Post #: 888
RE: Extreme Flight ... - 5/15/2008 1:53:44 PM
JoeAirPort
Status: offline
3DAP,
I got totally lucky and found this guy selling a like-new True Turn P51 4" spinner with a lightened back plate ($65 shipped...it's normally $100 shipped). It's very light and looks awesome. My CG is near the 6.5" but it needs to go back a little more. It still pulls slightly to canopy in knife edge. If I move it back a little more I should get no coupling (but I'd rather pull up in a knife edge than down). It got better the first time I moved it back but I ran out of battery leads so I could only go so far back. I will solder on 6" extensions and move the battery to the back of the tunnel. Flying is great. The B60 is running awesome. I really like the plane. It's all they say it is. For 3D the CG needs to be behind the 6.5 mark IMO. For a good middle point between precision and 3D the 6.5" would probably be perfect. For my taste, aft of 6.5".
Joe AP
       Post #: 889
