RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld Wilga PZL 35
Seller:  BAGOSTIX
Details:   $1,800.00   |  6/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Page: <<   < prev  35 36 [37] 38 39 40 41 42 43 44   next >   >>
Login
RE: Extreme Flight ... - 5/16/2008 2:35:47 AM
flyingcrazy
Status: offline
Did you flip the carb over ?
_____________________________
Rodney
(in reply to 6Packo Beer)
       Post #: 901
RE: Extreme Flight ... - 5/16/2008 3:42:45 AM
Rush7
Status: offline
6Pack the stop will not always prevent the butterfly from passing center. I had to look down the throat of my carb to make sure that the butterfly was exactly parallel with the throat. If you let it open all the way to the stop it can over-rotate and can start closing the carb back off. My DA is that way. I have to stop mine about 1/16" short of the stop.
quote:
ORIGINAL: 6Packo Beer
its open all the way, there is a stop that prevents it from passing center
http://www.crccflyers.org
Huckin' til it hurts
       Post #: 902
RE: Extreme Flight ... - 5/16/2008 3:55:18 AM
6Packo Beer
Status: offline
Yes I flipped the Carb Per DA's instructions, and I will double check the Throttle Stop to make sure its not closing - Thanks
< Message edited by 6Packo Beer -- 5/16/2008 4:01:02 AM >
(in reply to Rush7)
       Post #: 903
RE: Extreme Flight ... - 5/16/2008 1:35:27 PM
wavy777
Status: offline
So as far as a header for the ES pipe is there any difference bewteen solid and flex. I saw some people saying that flex didn't give as good RPM ? Also what is the lightest / best header out there for this pipe, MTW ?
I'm actually using a KS rigid header, 25mm drop. They custom make them for you, just let them know the dimensions and what motor they are for. Great Service too!
http://www.krumscheid-metallwaren.de/neu/shop.php?lang=EN look for accessories on the home page.
< Message edited by wavy777 -- 5/16/2008 2:15:00 PM >
       Post #: 904
RE: Extreme Flight ... - 5/16/2008 2:17:10 PM
wavy777
Status: offline
forgot to mention you'll need the header at about 12 - 13" long for best effect on an ES pipe.
(in reply to wavy777)
       Post #: 905
RE: Extreme Flight ... - 5/17/2008 1:48:48 AM
6Packo Beer
Status: offline
Ok guys I stripped out the smoke, cut down on a few servo extensions, stripped the landing gear to bare aluminum and took off the fusalage farings that will take the aircraft for 18.6 lbs Dry to 17.7 Lbs Dry, if I fly w/o the wheel farings its 17.5 lbs. I Changed the prop out for a Vess 22A which is a great looking prop. In addition I added a FASST Reciever and moved the CG about 1/16th of an inch past its reward limit of 6.3/4 from the LE. If I put the wheel farings on the CG will be just in front of the reward limit. If I want to get ballzy I can drop another 3.5 ounces by getting rid of my second reciever battery but thats enough changes for now. Tomorrow my Club is having a fly in and I am hoping to go see what I can get out of this DA with a vess 22A and and change in performance with a pound lighter airframe and more reward CG.
Sorry for the long post - I really appreciate everyones help thanks to all, I'll report back tomorrow PM on how it went.
For now on to a fresh 6 Pack !!!
       Post #: 906
RE: Extreme Flight ... - 5/18/2008 5:11:42 AM
6Packo Beer
Status: offline
Ok so today went much better. With a slimline pitts muffler and a Vess 22A I got 7250 RPM's - YIKES !!!, I got a fish scale from my friend and it seemed to be pulling 28 LBS of thrust. Flying was 100 % better than last week, just absolutely insane. I will continue tweaking, if I did put a tuned pipe on it RPMS would be nuts, over 7500 with a 22A or sure.
SPECIAL THANKS - to BAD BRAD Graphics.com
Brad was a pleasure to work with, I screwed up applying some graphics, he sent me replacements at no charge, 1st class all the way - if you looking for graphics call Bad Brad
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 907
RE: Extreme Flight ... - 5/18/2008 5:18:39 AM
6Packo Beer
Status: offline
more pics - Oh and as i said before I stripped the paint off the langing gear and left it solid Aluminum. If you polish it it's very shiney, I also tool off the fusalage farings for the landung gear. It's personal preference but IMO the silver gear looks much better.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by 6Packo Beer -- 5/18/2008 5:36:10 AM >
       Post #: 908
RE: Extreme Flight... - 5/18/2008 7:25:54 AM
Rush7
Status: offline
Very nice 6Pack. Glad your engine is coming around. Got to love those graphics. Brad is top notch when it comes to graphics.
Here is a pic of mine.
Click for fullsize
< Message edited by Rush7 -- 5/18/2008 7:28:15 AM >
       Post #: 909
RE: Extreme Flight... - 5/18/2008 1:32:50 PM
xtraflyr
Status: offline
We told you didint we? The weight isnt even an issue with these EF planes.. Im glad you had great success with it this time.
I also use Brad as my graphic guy.He is top notch. And his prices are very good..
www.njjf.org
www.njjf.freeforums.org
(in reply to Rush7)
       Post #: 910
RE: Extreme Flight... - 5/18/2008 5:01:47 PM
diamondave
Status: offline
becareful with that fasst receiver, there is a ton of us with them failing in the south west, they dont tolerate heat nearly as well as any reciever out there, they go into failsafe and wont come back until you cycle the power, its a bad deal, there is several posts out there here and on fg's site if you want to look it up, i went back to pcm in all my planes, just wanted to give you a heads up, id hate to see a fellow ef plane go down cause of something like that, i am sure it will be getting warm in your area soon too
(in reply to xtraflyr)
       Post #: 911
RE: Extreme Flight ... - 5/19/2008 4:38:56 AM
Sawacs
Status: offline
Hey,
What are you fellas running for RX and ignition power in your 300? Are you running dual RX packs or a single?
I just began building mine and have been banging my head on the keyboard trying to figure out which route to take with batteries and switches.
Thanks, Shawn
"Face Piles of Trials with Smiles"
AMA 219178
(in reply to flyingcrazy)
       Post #: 912
RE: Extreme Flight ... - 5/19/2008 5:29:37 AM
6Packo Beer
Status: offline
Hi I am Running Dual Troy Built Models 7.4 V 2600mili amp Li-ION batteries on the reciever. They weigh 3.6 ounces a piece and are plugged into a MPI Miracle Switch Mark 2, The MPI Switch weighs just over an ounce if I remember correctly. The output is regulated to 6.0 Volt to my reciever. For the ignition I have a 3rd of the formentioned batteries also run off a seperate MPI switch. I like my set up but the new A123 Batteries are light and dont require regulators which is nice. Regardless I think 2 batteries on the reciever is a good way to go. My advice would be to build with the lightest componets you can so you dont end up over weight.
Good luck building - And so you know regarding the composite control horns, the " short set" go on the rudder, the elevator ailerons all get the same long stem control horns - this is not mentioned in the directions.
< Message edited by 6Packo Beer -- 5/19/2008 5:30:58 AM >
(in reply to Sawacs)
       Post #: 913
RE: Extreme Flight ... - 5/19/2008 5:38:29 AM
Sawacs
Status: offline
Thanks for the info 6pack!
I'll look into the TMB stuff and see where it leads me..
The A123 batteries do sound nice simply because you don't need the additional regulator.. Humm, you just made me think of something!
One Wolverine switch hooked to two A123's for the RX and ignition.. That would make a simple setup with no regulators..
I'm outta here and thanks again. Off to do more research and head banging on the keyboard.
Shawn
AMA 219178
       Post #: 914
RE: Extreme Flight ... - 5/19/2008 5:46:14 AM
6Packo Beer
Status: offline
Yea if I had to do it over i may have gone with the A123 Batts. Just make sure to keep your reciever and ignition electronics totally sepreate, do not use reciever power to supply ignition power as well, thats just asking for a disaster.
       Post #: 915
