diamondave
AZ, USA Status: offline
yes i did loose a plane cause of an mpi switch ....so now i use the wolverine 2 in 1 for my reciever, but the fasst thing with heat can be a problem, mine failed, luckily on the ground just before take off, and i mean just b4 take off, my hand was on the rudder ready to pull out from stand, got locked out, turned power on and off and it came back, then shut out again, did that 3 times, took it home and it worked fine, then i found some of the threads about the heat problems others are having, i had the EXACT same symptoms with mine, i truly believe it was heat related, i sent it back to tower after getting a runaround with futaba, tower refunded me no questions asked, so now i am using my pcm again, i still like thet 9c radio but man hearing how bad futaba treated 6pack makes me want to change myself, i know they dont want to admit the problem with heat, but they are still selling them, there is going to be ALOT of failures this summer, mine failed at the end of april here in arizona, everyday that goes by they dont do somthing i dye a little inside, haha, my loyalty to them does anyway, sorry about the loss 6pack, when i lost my other plane to the mpi i got out of the hobby for a while, it was devistating to loose a plane cause of a failure like that, not my thumbs, and that was my 1st big gasser, i wont touch a mpi product anymore, anything from them i dont care what it is, electronic or not, my switch failed and when i looked at the back of it, once the case was off, the soldering job was rediculous, hardly any solder on 2 of the main wires, you could almost not even tell where it was supposed to go, it was the fancy switch with the led's on it, and i did find out more people had the same problem with that switch too, as far as fasst, there is some "heated" discussions on fg's site about all that, i will stick with my pcm for now, but contemplating a brand switch down the road, just cause i am following the problem and dont like the way its being handled at all, again sorry 6pack
