TN, USA Status: offline
Bills right. You can get all the skinny on the new plane at www.extremeflightrc.com Looks to be an 88" Edge 540. You know if it comes with the EF logo on it.......it has to be awesome.
WA, USA Status: offline
Finally got my flying!! This plane is really rock solid. No coupling in KE, No wing drop at stall, It flies OOOHHH SOOOO slow. Any way I love this F@%@#%% PLANE!!!!!!!!!!!!!!! The stock exhaust on my B60 is not providing enough Power for me Though. So after driving Ruddy crazy for a while I think I am going to drop 250 more on this project for a KS Exhaust. Now, 6600 on a Xoar 23 x 8, 7150 on a 22 x 8. I would really like to have 7500 on a 23 x 8. I have some Vess props on the way. Hoping I might see better results with them. Running 40 : 1, 2 gallons thru it, High needle 1 1/8 out, Low needle 1 3/16 out. 300 feet above sea level. B60 runs very, very well. Good transition from low mid and high. It idles very low. Just not enough Rpm's yet. I did flood it the first couple of flights though. I flipped the F&*& out of it and finally realized I flooded it. My shoulder hurt the next day after flipping so much! Then I pulled the plug and drained cyl. After that I have had no problem starting. 3 clicks of throttle, choke on until it pops. Then 4-5 flips choke off. It has been working good this way. Thank You Chris, EF Kicks A$$
DE, USA Status: offline
Throw out the Xoars first off If you get a Mejzlik 22x8 you will be a lot happier for 3D. Actually first off.. congrats on the madian... then throw out the props The Vess should be ok as well but they are loud. Don't do a 22" Vess not enough load 23 A or B is where you want to be.
FL, USA Status: offline
Hey guys,
Can anyone recommend a good tail wheel bracket. Mine was destroyed today during a not-so-perfect landing. I wouldn' t mind a little extra weight for the tail either.
WI, USA Status: offline
I came to post after flying today. Wow do I love this fricken plane. It does everything you want it to with the best behavior. I got the B60 starting pretty easy now. Awesome awesome awesome. The Xoar props work great for me. Carbon is too heavy and expensive. I have an MSC 22x8 waiting to try after I get enough fuel through it. The B60 is perfect for this plane.
PS: You could try the Graphtech tail wheel brackets.
< Message edited by JoeAirPort -- 8/9/2008 10:58:18 PM >
I have the 22A coming for the brison 3.2 and the 23A arriving for the B60. Before I buy another prop I am going to buy the KS pipe then probably the Carbon 23 x 8 MEJ. Jake which Da header is the one I want? Also where is the link for your review that shows your Ks set up????
Its this kinda talk,that gets me interested again.Seems the thread was kinda quiet,with hardly anyone screaming with exitement. I still plan on getting one,most likely over over the Winter now.They should be on their 3 or 4rth run by then,with most small bugs worked out.Not really anything on the market that I really want besides this one.
To own one of these is a real treat. It's like going out and buying yourself the best, and every time you go fly, it's a total awesome experience. People that see this plane at my club have lots of great comments when they see it in action. Today a guy I didn't know just drove up in his car while I was flying. After I landed all he said was "that was quite a show...I thought it was a real plane at first". Another guy earlier said "that was quite a workout" after I landed. You just gotta love owning one of these planes. It gets lots of attention at the field. I will own many more of these EF planes.
