RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Page: <<   < prev  50 51 [52] 53 54 55 56 57 58 59   next >   >>
Login
RE: Extr... - 8/11/2008 1:56:16 PM
Williamclegg
Status: offline
I weighed in at 17.5 pounds with pilot, pants, etc.
(in reply to JoeAirPort)
       Post #: 1276
RE: Extr... - 8/11/2008 2:29:46 PM
JoeAirPort
Status: offline
They must be getting lighter. Many of the first ones were 18+ pounds with everything installed.
For grins I looked up the wing span of a full scale Extra. There are many variations of an Extra but I found two different wing spans. One was 24' 3" and the other was 26' 3". Depending on which one you use I get 28.1% and 30.4% for this ARF. I haven't been able to find anything on a 300EX which is what this is apparently modeled after.
< Message edited by JoeAirPort -- 8/11/2008 2:41:44 PM >
_____________________________
Joe AP
       Post #: 1277
RE: Extr... - 8/11/2008 7:32:31 PM
nitro wing
Status: offline
quote:
ORIGINAL: JoeAirPort
Lighter may be tough. I'm at 18 pounds built pretty light (light engine, one rx batt, no pilot, no instrument panel). The Edge is 17.5 pounds also built pretty light. They are very close in weight actually.
I have the first generation one,a bit heavy,especially the foam core sheeted wings.I think I am at 18 pounds also with smoke,maybe more??
One day I will weigh it.
       Post #: 1278
RE: Ext... - 8/11/2008 9:10:17 PM
Rush7
Status: offline
I never knew that there were any out there with foam core wings.
http://www.crccflyers.org
Huckin'' til it hurts
(in reply to nitro wing)
       Post #: 1279
RE: Ext... - 8/12/2008 12:28:35 AM
Jake Ruddy
Status: offline
I had one of the first 10 that arrived in the darkness of night before the first batch even arrived and 1 of the models from the 1st or 2nd batch... neither had foam core wings.
Weights are kind of like rpms Both of mine weighed within 1/4 pound of eachother before choosing the muffler setup. There are people claiming sub 17 pounds.. aint going to happen. They are going to weigh 17.5 - 18.5 pounds no matter how you slice it.
(in reply to Rush7)
       Post #: 1280
RE: Ext... - 8/12/2008 12:41:26 AM
RC Extreme power
Status: online
Ours on postal scales 16.5 lbs with Area 51 engine and stock muffler.
Importer of high performance RC gas engines
www.rcextremepower.com
(in reply to Jake Ruddy)
       Post #: 1281
RE: Ext... - 8/12/2008 6:54:48 AM
nitro wing
Status: offline
Sorry guys
I was chatting with Joe about weights and foam wings on the old BME Edge 540..
He has the newer Edge and I have the old Edge.
He is also flying the EF 300 and the above posts were about performance and weight differences of the Edges to the EF 300.
(in reply to RC Extreme power)
       Post #: 1282
RE: Ext... - 8/12/2008 2:32:15 PM
JoeAirPort
Status: offline
quote:
ORIGINAL: RC Extreme power
This is a rare case....
Joe AP
       Post #: 1283
RE: Ext... - 8/12/2008 5:16:03 PM
JoeAirPort
Status: offline
quote:
ORIGINAL: Jake Ruddy
Jake, your honesty (and accuracy) will be greatly appreciated by people who visit this thread. I had the same experience. I weighed two fuses, the heaviest part of the ARF, and one was one once lighter.
Joe AP
       Post #: 1284
RE: Ext... - 8/12/2008 5:52:41 PM
6Packo Beer
Status: offline
My first Extra came out to 17 3/4 lbs w/o a smoke set up or fuel. The engine was a DA50, slimline pitts muffler, Hitec 5955 TG's on all surfaces and a Hitec MG servo on throttle. I had a CF spinner and prop, 3 2600 TBM Li-ion batts, 3 MPI Regs and 2 MPI switches. I followed the set up of a guy i saw online claiming 16 1/4 LBS, I agree its most likely BS. For those who claim 16 ish pounds put your plane on a scale all set up, take a PIC of the inside and out with it on the scale, and post it on this thread. I am building a second extra after the unfortunate demise of my first, I am hoping it will come out at 17 lbs, I switched to an ES CF pipe to hopefully cut some weight.
>>>As a side note ES is making pipes with a steel inlet insert rather than aluminum to hopefully prevent any deformation of the inlet at high temps. Although Ed from ES denies that this is a problem to begin with.
       Post #: 1285
RE: Ext... - 8/13/2008 4:55:08 AM
Jake Ruddy
Status: offline
I used Titianium axels, super light wheels, light bateries, CF Spinner and the works... the fact is.. even at 18 pounds with the sqs on this plane it doesnt matter. It flies light and thats just basic math. AT 28 oz wingloading for a plane this large.. thats some of the lowest wingloading you will find.
This plane is almost as big as most 33%ers that come out at 24 pounds. I have one sitting here to prove it. It just has 10" on the wings. and its 6 pounds heavier. No one is finding magic ways to save weight... look how the plane is built, there is no where left to lighten it.
< Message edited by Jake Ruddy -- 8/13/2008 11:31:50 AM >
(in reply to 6Packo Beer)
       Post #: 1286
RE: Ext... - 8/13/2008 5:11:39 AM
3DAP
Status: offline
Jake,
Right again you are. This plane flies so slow it is ridiculous!!!!!!!!!!!!!!!!
       Post #: 1287
RE: Ext... - 8/14/2008 5:32:14 AM
T. Bob
Status: offline
Just about everyone lies.
Thank you
< Message edited by T. Bob -- 8/14/2008 5:33:02 AM >
"This plane has no limits as to performance with this engine except vertical"
(in reply to 3DAP)
       Post #: 1288
RE: Ext... - 8/14/2008 3:38:05 PM
JoeAirPort
Status: offline
I checked my scale against a calibrated lab scale at work and it was within a few grams. You can trust that anything I weigh and post here is going to be accurate......And I weigh everything. For example I wanted to strengthen my wheel pants because they got weak from being kicked and bumped. The right one was 1.2 ounces, and the left one was 1.3 ounces before the repair. Afterwards they were 1.5/1.6 ounces. These wheel pants are feather light. I would recommend glassing over those ply plates where they attach to the main gear.
As far as how this plane flies at 18 pounds......light.....and awesome. I can't wait to burn another gallon through her this weekend.
Joe AP
(in reply to T. Bob)
       Post #: 1289
RE: Ext... - 8/14/2008 4:23:20 PM
wavy777
Status: offline
my extra is 18lbs dry, no smoke, DL50 on ES comp pipe. Still flys like a foamy...
       Post #: 1290
RE: Ext... - 8/14/2008 7:19:00 PM
Rush7
Status: offline
Mine came in at a whopping 18.75 lbs with everything on it and a DA-50 with an MTW tuned pipe. Mine flies fine. Seems light enough on the wings and still has enough power to get me out of a bad situation.
So pushing 19lbs the plane is awesome. I could take the wheel pants off, take out the pilot/instrument panel and mounting hardware, changes the wheels and tires, pull the spinner off, get rid of one battery and things like that and get lighter........but why. This thing flies just fine the way it is and it is going to stay that way.
Mine was one of the very first one and I dont really know what changes Chris has made since then. I am pretty sure that mine came out of the same batch as Jake's first one.
(in reply to wavy777)
